Throttle body question
Old Jul 18, 2008 | 08:28 PM
BULLETSSMOKE's Avatar
My CAI gets more air than most usually do and its loud as hell and I was wondering if I could benefit from a slightly larger throttle body. If I would benefit from one, which one would be good to get and do I have to tune it?
Thank you
Old Jul 18, 2008 | 08:45 PM
outtamymind's Avatar
everyone can benefit from a larger throttle body its a matter of finding one that will work correctly with yours and yes you would have to tune for it
Old Jul 18, 2008 | 08:48 PM
what would be a good one you think? one that can directly bolt up or almost directly with light modification
Old Jul 18, 2008 | 08:56 PM
your best bet would be one that would directly bolt up. cuz we have a few sensors that hook up to the throttle body and i'm not sure which ones would work with the 2.4's
Old Jul 18, 2008 | 09:43 PM
theneelster's Avatar
Remember you may need a spacer to accommodate the larger butterfly. Does the 2.0 tb fit the 2.4? Post pictures I may be able to tell you.
Old Jul 18, 2008 | 09:54 PM
no the 2.0 wouldn't fit due to the sensors and manifold, i'm 99% sure on that one. and yes i forgot to mention the spacer
Old Jul 18, 2008 | 10:45 PM
cDub's Avatar
please entertain me with your idea of how a larger throttle body will increase your performance JUST because you made the inner diameter bigger, and you now have a longer tube with an open air filter thats is loud.
Old Jul 18, 2008 | 11:01 PM
Beck's Avatar
https://www.cobaltss.net/forums/show...ghlight=wiring
Old Jul 18, 2008 | 11:20 PM
ahhh thank you very much, i remember seeing this post a while back. but do you forsee any worthwhile gains out of this little project or should i not even do it. im down for doing it just for the hell of it though lol
Old Jul 18, 2008 | 11:32 PM
cDub's Avatar
no you would see little to NO benefit from doing this modification. if you decide to throw an intake manifold on it, then change the tb, until then... i can think of 100 things you could spend your money on other than a useless mod. a few examples including beer, things that will actually help your performance, beer, a shorty antenna for me, beer or even prostitutes. go you.
Old Jul 19, 2008 | 12:17 AM
the best you would hope to gain is some throttle response difference with this but i agree you would see very little actual performance HP gains from this mod.
Old Jul 19, 2008 | 12:02 PM
ok PASS, thanks for the input. just had an idea of possible hp gains.
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
