Throwing the 2.8" + 60's on in a few weeks
if we start seeign crazy knock we can't get rid off due to the compression ratio, then i'll have to bump it up to 3"...otherwise, if AFR's are good and there is no knock 2.8" is going to stay.
Anxious to see the outcome of this for sure. Take it the blower is still running strong for you then! She certainly was a good girl for me! If I come up to NH this summer and you're still up there, we'll have to meet up at the track.
pjk: also, you might want to rethink the 60's if your going to ever want a 2.7-2.5... 2.8 will be all those injectors can handle at 7k rpm (meth will defiantly lower duty cycle), but maybe 79lb'ers would be a better investment if your going to want more... and you will want more... you know you will...
Why would 2.8 make LESS power than 3.0?
Meth is also an option. Beck suggested an EGT gauge, and I know someone with one FS. Might pick that up as well.
You will not need 79lb'ers. the m62 cant flow enough air for the 60's anyways so dont worry. stick with the 60lb'ers and your set. Invest in a dualpass endplate and you shouldnt have an issue with the 2.8". You could make close to 285whp if Area47 tuned your car
since he probably wont you could do 270whp if you can tune it right.
not to flame, or cause an argument,
buttt...
your sig says: Blown:228whp 208tq and 14.719 @ 98mph 2.41 60ft
do you think you can drop a whole second(and then some) with just 40 more whp?
Smaller pulley = less rotational mass...plus the faster the blower..blows.
Last edited by Turbo06Sedan; Apr 23, 2008 at 09:59 PM. Reason: Automerged Doublepost
Id really love to see these 2.4's supercharged and push over 300hp.
We're all brothers in this....the 2.2's are like our little sisters...and the 2.0's are like the ****** older cousin who thinks hes better than you.
We gotta stick together.
2.4's FTW.
2.4's FTW.
what signs of wear is he seeing? can you elaborate? I'm still doing it anyways...there are cars runnign 10.4:1 + boost no problem. If the tune is solid, there are good afrs, no knock...it will be ok.
Sure I'm going to need studs/headgasket for safety's sake, as well as a clutch and probably springs, but other than that I feel confident the internals are strong enough to hold on to M62 12-15psi on a daily driver.
