Throwing the 2.8" + 60's on in a few weeks
my tune is set to start off with 11.5 af ratio and then towards the top in progress to 11.0 for safety
negative
my **** is fine, did compression test and leak down test. The dipstick just wasnt pushed in all the way. didnt pop out. The breather is spitting oil now no longer 'foam'
I can read post blower temps, just not pre blower temps. pre blower temps dont really matter though anyways.
you did go with the 2.5 Bar map right? if you wired it up in accordance with the diagram in my how two the IAT you are displaying is post blower, not pre.
my **** is fine, did compression test and leak down test. The dipstick just wasnt pushed in all the way. didnt pop out. The breather is spitting oil now no longer 'foam'you did go with the 2.5 Bar map right? if you wired it up in accordance with the diagram in my how two the IAT you are displaying is post blower, not pre.
negative
my **** is fine, did compression test and leak down test. The dipstick just wasnt pushed in all the way. didnt pop out. The breather is spitting oil now no longer 'foam'I can read post blower temps, just not pre blower temps. pre blower temps dont really matter though anyways.
edit: I think I might work on the Map/Maf blend. someday.
However, by disabling, or not having a map you will mess with other aspects of fueling. transit fueling, map hyst's for enabling and disabling functions (PE, DFCO, etc), thats only to name a few. GM uses multiple sensor inputs to create "virtual" sensors for alot of different things. if you want an example of this, go pull your knock sensor.
even beyond that i believe map is still used to help calculate the second axis of the spark tables (see discussion in pjk's thread a while back with witt). I havent had time to prove or disprove that yet. anyways, end rant..
steps needed to tune for boost are this:
disable dynamic airflow
rescale map
disable some annoying codes
tune IFR, PW, offsets then MAF
forget VE, the point i've been trying to make is that you shouldn't "delete" or "disable" map. the best route for our cars is to use the 2.5bar tmap in the lsj-stock location and allow MAP operations to work normally.
horsepower is a theoretical number derived from torque, this just doesn't make sense.. the point of the smaller pully is more boost, more boost = more torque+power
What a douche bag, 2.0 has potential... the rest have potential for headaches...
Since at 8psi Im 1+ second faster than Stg 2 + alot of boltons in the 1/4 who are boosting 17+
The 2.4's have the potential.
Dont get pissy because a lesser model than yours is faster
ugh I really don't like a reply like that, but whatever.
The 2.0 does have good potential.
So does the 2.2.
And so does the 2.4.
If all things were equal, besides displacement (2.0 and 2.4) sure the 2.4 would yield higher tq/hp numbers. There are also good things to be said about 2.0's and "square motors". They have their advantages.
So does the 2.2.
So does the 2.2.
So does the 2.2.
Was merely stating stock for stock, the 2.4 is alot better of a motor. Mainly for the VVT.
Dynojet(egojet) "guesses" your crank HP...which is inacurate because your never certain what the exact drivetrain loss is.
it varies by transmission....one FWD car could have more of a loss than another FWD car.
oh ok cool. sry for the noob, but ive never been dynoed nor had experience with them. thanks
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Iceberg
Sep 29, 2015 12:33 PM
