Try Erasing ECMs Occasionally
Old Apr 11, 2008 | 08:56 PM
Red07SSNA's Avatar
My SS/NA has been accelerating a little too slow for me lately. I've been driving the car like a "grandpa" for the best gas mileage lately and was a little disappointed with the get-up-and-go. Just to see what would happen, I erased the codes in the ECM -- even though I didn't have any so that it would have to re-learn again (this sets the sensors back to the original specs and the ECM begins to re-learn all over). First thing I noticed when I started it was the exhaust was a lot quieter and smoother -- I have CED's RT 2.75" cat back -- so it was very noticable. The acceleration feels quicker. If you have a scan tool and can erase your ECM you might consider doing this if your 2.4L seems a bit sluggish. It would be interesting to see what would happen on a dragstrip -- before and after to see what effect this would have on ET and MPH -- especially after driving the car slowly in stop-and-go traffic for a month or more.
Old Apr 11, 2008 | 09:10 PM
Jimmys2007CobaltSS/C's Avatar
how much is the random tech exhaust and how much did it cost u
Old Apr 11, 2008 | 09:21 PM
Red07SSNA's Avatar
I got a package deal from CED by buying lots of parts:
http://www.crateenginedepot.com/stor...P1829C146.aspx
Old Apr 11, 2008 | 10:03 PM
any sound clips....2.75 bolt up a 3 inch d/p with 2.5 exit??
Old Apr 11, 2008 | 10:13 PM
bigworm's Avatar
if blowing out learned spark/fuel trims means your getting more performance you need a tune, or switch fuel grades.
bad terminology btw, i erased my ecu once... battery went out while 'write entire'... defiantly not a performance enhancer.
Old Apr 11, 2008 | 11:31 PM
Red07SSNA's Avatar
I don't have any and don't have a way to do it -- there is some on the site but hard to find with search because they're part of other threads. My RT cat-back bolted up to the stock downpipe.
Not pushing it as a performance enhancer -- if you drive your car easy for a long time the learned settings will convert to help you get MPG. Bringing it back to the original settings will allow the car to work towards HP. Since I don't know how to tune and no one provides the specifics on how to do it ("just get HP Tuners" doesn't describe how-to for the novice) this could help someone when they take it to the track every once in a while.
Old Apr 11, 2008 | 11:40 PM
REDFOCZ's Avatar
Cough***click link in my sig Cough*****
Old Apr 12, 2008 | 12:02 AM
Red07SSNA's Avatar
OK, I read it again. Look at post 32 and 35. What is needed to make the pretty pictures you posted (PNs, model No.s, cables, etc.). Remember we're not all computer-literate.
Old Apr 12, 2008 | 08:43 AM
CSM Huber's Avatar
How about just disconnecting the negative lead of the battery for 10 minutes?
Old Apr 12, 2008 | 10:06 AM
Red07SSNA's Avatar
I'm not sure this resets the sensors. The factory service manual says to clear the ECM to reset the sensor values. It doesn't mention anything about disconnecting the battery to do this. Seems like it would but not sure.
Old Apr 12, 2008 | 10:12 AM
originaladrian's Avatar
thread quoted for truth.
I did this on my 2.2 after my intake and exhaust and felt a difference. Smother idle and less throttle lag.
Old Apr 12, 2008 | 11:05 AM
dtabbs's Avatar
On old OBDI systems, diconnecting the battery for an alotted time did reset the ECM/ECU. On a OBDII system that has been on cars since 1996 that does not work. The ECM now have a CMOS battery just like a PC so disconnecting the battery will do nothing.
On the other hand if you have a Interceptor guage it can be done from that as well, or just visit your local Auto Zone store and ask them very nicely and they will clear it for you.
Old Apr 12, 2008 | 12:14 PM
Red07SSNA's Avatar
Thanks...that makes it crystal clear!
Old Apr 12, 2008 | 12:48 PM
Turbo06Sedan's Avatar
when i used to go on long trips (country wide), id run 87 octane gas, just because it was cheaper.
when i got to SLC, UT with the higher elevation, and id run 93 again, the car ran like crap (no getup and go).
I found that filling your tank with 93, plus an octane boost(which will help overide the 87 **** that was in before), then unhooking the battery, smoking a cigarette made a difference.
Now that i have to run premium gas regardless, i wont have to worry about that.
GaryGibblez
Jan 14, 2020 10:35 AM
almcphee
Sep 23, 2015 09:55 AM
soundjunky
Sep 3, 2015 01:18 PM
Jroy326
Sep 1, 2015 07:37 PM
Modernceo
Dec 9, 2005 01:54 AM
