Tsudo N1 exhaust fitment
Old Oct 3, 2011 | 06:21 PM
145CIBALT's Avatar
Hey Guys,
I was looking at this exhaust and noticed the one for the SC has slightly larger diameter tubing at 2.5" vs the one made specifically for the 2.4 at 2.36". Does anyone know if the one made for the SC will fit the 2.4L?
Old Oct 3, 2011 | 06:33 PM
Omnigear's Avatar
it should generaly fit, slight modification might be required . on my old hhr it had to be cut 1" off so it doesnt stick out. i say it will fit.
Old Oct 3, 2011 | 06:40 PM
145CIBALT's Avatar
Where did the cut the inch from? Did they have to weld a flange back on?
Old Oct 3, 2011 | 07:18 PM
Omnigear's Avatar
yes , they cut it dp/res area. you shouldnt need to cut anything since its the same. only thing is the dp to resonator section i think. idk if its the same length or not.
Old Oct 4, 2011 | 12:39 AM
Dee_Balt07's Avatar
It will fit. 2.5 is the highest u should go on a N/A motor any way.
Old Oct 4, 2011 | 01:10 AM
noorj's Avatar
+1 for fitting fine, no modification needed
Old Oct 4, 2011 | 01:11 AM
blu3_v1p3r's Avatar
Any exhaust and parts available for any cobalt are interchangable with the exception of manifold and DP of the SS/TC . Now, you shouldn't go out and buy 3" exhaust for your na car, 2.5 is the higest you should go.
So yes fitment wise it will be direct bold on.
Old Oct 4, 2011 | 01:14 AM
padlock's Avatar
well fitment wasnt perfect with mine.. but its an easy fix as seen
BEFORE
AFTER
Old Oct 4, 2011 | 06:45 PM
145CIBALT's Avatar
Thanks guys for the info and no worries. I wasn't going to go any bigger than 2.5" pipes.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
