Which turbo?
i want a kit for my 2.2, but im worried about wear and tear on my car. I plan on getting full sways and a full exaust. Also a new clutch, with all that i should be okay to run the garret at 10psi with minor to no problems or what??
bump ne one got n e ideas?? looking spend about 1k
Last edited by BlackMachine; Apr 11, 2008 at 04:10 PM. Reason: Automerged Doublepost
10psi with all those mods I don't think would be a problem, I wouldn't go any higher. Just remember to change your oil every 3000 miles after the turbo. The higher cylinder pressures lead to fater contamination of the oil.
doing your own ic/piping wont be that bad...hell the intercooler ive already gotten rigged up and tested on the car(without taking th bumper off) and it fits perfect and looks great...now the piping as far as compressor side of the ic should be easy..but on the throttle body side its looking like its going to bea bitch
stupid question...i went onto the garret page and looked under 2.4 turbo and thers a link for the hahn site.....
also...from waht ive seen and from the little that i know about turbos im liking the hahn kit even tho its more expensive just b/c it seems to be as complete as you can get...as for the issues with the tune...how had is it to rectify the problems associated with it?? is bill going to make any changes to the tune he provides based on whats been going on??
My tune is available from Vince at Trifecta Performance for much less than I paid to have it made. PM me for more information on the tune and what you need to make it work as an alternative.
I paid $1000 for the time to retune my car to work without the parts and the tune that Hahn provided. I talked to Bill about it and he had no interest is what we did with my car.
ny to wa is a lonnnng distance lol
With my tune you could run the kit without any fuel system mods except the 60# injectors.
Not sure what you mean by blow through? I didn't change any of the charge piping if that helps!
He is sending one to PA this week!
I was just asking where you had the MAF located, if you have not changed the piping you are running a draw through set up since it is before the turbo, blow through would be after the turbo.
if you're only looking for 220 and reliable and cheap either get nitrous.. the m62 redline setup... or a full na build with cams .. and you'll get there with all of them and be reliable.. or just an ebay turbo setup like trix.. it's not worth buying a kit if you're looking for only a mear 50-75 hp depending on other mods
