ugh where are the spark plugs...
Old May 22, 2010 | 10:27 PM
StevoElSupremo's Avatar
I really REALLY hate to sound like an idiot but I've never worked on this car before (besides an oil change..)
where the heck are the spark plugs?!! on all my old cars I just followed the fat distributer wires to them...
are they those 4 plastic caps on the engine head? or are those the injectors? do I need to changed the wires as well?
again I know I sound like a tard but I'd really just like to know
Old May 22, 2010 | 10:31 PM
roderick's Avatar
its on top of the engine there is a metal plate with like 6 torx screws. remove the screws the cover pops off and they r there.
Old May 22, 2010 | 10:34 PM
Caligula's Avatar
When I first got my balt I had no idea either.
Old May 22, 2010 | 10:38 PM
madmark's Avatar
2.4 does not have a coil cover, the 4 coils are on the top of the valve cover (remove the 4 black coils) and i believe its a 5/8ths spark plug socket
Old May 22, 2010 | 10:40 PM
Chevycobaltss3's Avatar
Kids lol j/k if you have the lnf 2.2 or 2.4 u will have coil on plug the black things on top the motor get a 10mm and take te bolts that hold them in and kabooom if u hav the lsj take the cover off in the middle of the valve cover and remove coil on plugs
Old May 22, 2010 | 10:50 PM
yup I gotta 2.4, thats why I posted in the 2.4 section
so there under the black plastic plug pieces on the engine head? are those the injectors as well?
Old May 22, 2010 | 10:55 PM
08G5GT2.4L's Avatar
no those are the coil packs. remove the bolt holding it down and pull up.
Old May 23, 2010 | 08:07 PM
Well I changed them today, put some anti seize on the thread (tiny amount) and I used NGK Iridiums fires up fast now
oh and before anyone goes and tells me "oohh dont use anti seize its evil!" blah blah I use it on all spark plug changes on Aluminum heads.... I dont feel like cross threading my heads again ( i did it on a car before) so now i always put a small dab of anti-seize on the threads and screw them in....and I'm quite careful as to not get it on the electrode or near the top...
Old May 23, 2010 | 11:27 PM
Ion's Avatar
Ion
I switched to Iridiums, but put in AutoLite or something like that. For a mild NA build, its not a big deal for me. When and if I turbo, NGK will def be in there. Those plugs are deep in there.
Btw, the injectors are on that rail that sits atop your engine. Pretty simple to get to as well. I like GM engine building for that.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
