Underdrive Pulley
Old Jan 27, 2010 | 12:59 PM
gordon1991's Avatar
Underdrive Pulley
Just ordered in the mrz underdrive crank pulley. I will also be doing my alternator pulley. If im not mistaken there is a Crank bolt that is needed to install the pulley. Does anyone have the size or part number for this. Also, what tensioner works best to rent?
Old Jan 27, 2010 | 01:12 PM
wesg631's Avatar
Cobalt addiction has the crank bolt cobalt-addiction.com
Old Jan 27, 2010 | 01:33 PM
gordon1991's Avatar
Is it necessary that i change the bolt?
Old Jan 27, 2010 | 01:44 PM
wesg631's Avatar
I would just to be safe they are a torque to yield meaning that onced torqued down to spec they should not come off
Old Jan 28, 2010 | 07:11 PM
Red07SSNA's Avatar
^^^ Correct, replace the bolt. They are meant to be used once! Factory service manual specifies this. The part number is 1158912? -- crap the tag on my new bolt is torn at the end!!!!
Found my old picture:
https://www.cobaltss.net/gallery/fil...nce_pulley.jpg
https://www.cobaltss.net/gallery/sho...08&c=favorites
PN is 11589123...LoL
Old Jan 29, 2010 | 01:25 AM
collins14ss's Avatar
just how much power can u get out of these pulleys?
Old Jan 29, 2010 | 01:33 AM
xxxxsh4d0wxxxx's Avatar
^ You won't make much, if any, noticeable power, anyway. It's for freeing up power, and quicker revs.
Old Feb 7, 2010 | 05:28 PM
Turbo06Sedan's Avatar
Technically, you want make ANY...you are merely freeing up. As for example, it takes 10hp to turn the stock crank. The new one might take 5hp to turn.(Keep in mind these are BS numbers). You free'd up 5hp...so if your car was at 200hp...you'd be at 205. The engine itself isnt making any more...you're just seeing the increase due to the engine not having to turn a massive crank.
Old Feb 7, 2010 | 06:21 PM
Great explanation!
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
cw383
Sep 30, 2015 12:41 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
