Upper engine mount s/c install
I'm planning my install of the m62 and I have everything I need except for I'm still not quite sure if the upper mount needs changed by looking at pics and at mine it looks like my mount is in the way of the new belt tensioner....? 2008 g6 idk if it's different from the balts but I doubt it.
The LSJ tensioner is used with the LSJ alternator bracket. Do you have the alt bracket as well? Then your going to need 3 M8x1.25x125mm bolts to attach the alternator since the bracket spaces it out.
Also try to find the bolts at a hardware store if you can for $3 ea...they are $8 ea at the dealer.
found it. https://www.cobaltss.net/forums/part...artout-271699/
I was running a TTR upper mount and it cleared fine so not sure on the stocker. When I said mount I meant the engine hook. I had to remove that and remove material from the mounting area for the LSJ tensioner to clear.
[/IMG]
