Vector tunage
My full plans is to eventually get a CA Headder (wrapped and sprayed) and to modify the existing exhaust and possibly cams if the price comes down several hundred bux then get a dyno tune. But till then TC has got to go If TC just goes away it will be worth it.
Ok i tested it durning lunch. TC is still existant but It no longer what i would call an issue its almost like they made the TC come on at the perfect time instead of any time your tires spin. The changes to the way the car drives is unreal you will honestly not beleive its the same car. It feels more powerful across the chart. Its not like it has gobbs of tire shredding torque off the line but when you punch it the car will set you back a smidgen. Its acceleration feels Solid for lack of a better term. From the moment the car starts pulling it keeps pulling then it pulls even harder when the enrichment kicks in its a smoother acceleration it just seems to flow into the vvt change instead of a lag in power then the VVT kick.
...its beautiful
This mod was honestly more than worth the money.
...its beautiful
Coors
Aug 17, 2007 07:59 PM
