vibrant cel
Old Jul 1, 2008 | 06:27 PM
M_Dansx3's Avatar
vibrant cel
I know i've seen it before but now that i need it i can't find it. Does anyone know offhand which supporting vendor or outside vendor carries the spacer for the O2 sensor when the vibrant header and dp throws a CEL?? thanks much!!
Old Jul 1, 2008 | 06:30 PM
Jn2's Avatar
Jn2
autozone has the non foulers that do the same for 1/3 the cost
Old Jul 1, 2008 | 06:54 PM
M_Dansx3's Avatar
how would you actually make that work? did anyone else ever post a "how to" on it?
Old Jul 1, 2008 | 07:30 PM
dtabbs's Avatar
I dont know about a how too, but what you do is by the two pack of the non-fowlers from the "Help" (Motormite) section. Be sure that you buy the non-taper seat type. Use a drill bit that is slightly larger than the probe on the O2 sensor and drill through one of them. After that is done you would screw the two together (the one with the newly drilled hole inside the other) and then your O2 senser inside that. Bend the crap out of the heat shield under the car (this is why the other is so expensive cause you dont have to do that) and install the new assembly in the exhaust pipe behind the CAT.
Old Jul 1, 2008 | 07:39 PM
Stouffer's Avatar
https://www.cobaltss.net/forums/problems-service-maintenance-69/cheap-way-get-rid-p0420-116943/
With the Vibrant set up you shouldn't have to bend the heat shield.
turbochargedss2012
Sep 20, 2023 12:17 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
hacadacalopolis
Sep 8, 2015 11:42 PM
