VVT question (simple)
so let me get this right, you guys are saying vvt can hit anytime because of the senors and pressure n what not, so i would be in vvt at idle and the next day hit it at 6 grand? and actually i took off my muffler and i could tell it pushing more air out around 2500 rpm range, that might be when it starts
Try to keep up. It doesn't "hit" at any rpm.
Your valve timing is continuously varying with different engine speed. Hince....CVVT
Constant VVT
The VVT in the 2.4 is not an "on" and "off" system. The intake and exhaust VVT solenoids control the amount of oil pressure and movement of the cams so the cams move when the ECM senses the need -- can be a few degrees or maxed out (via set parameters in the engine management programming).
i get the basics of vvt- cam shaft lobes keeping the vavles open longer for more a/f to come into the engine, but why do i feel a burst of power VERY time i pass 4 grand? i mean i feel it at 3grand but its not as powerful
There is more to it, but thats the basics from what I understand.
Your in your power band and PE (Power Enrichment mode) has kicked in. PE is a tuning map on the PCM that, that basically says ok your not trying to save on gas anymore you've got your foot on the floor and your past the normal shifting point, its time to advance some timing and make the most power possible.
There are 2 solenoids, one for each CAMSHAFT. The Ecotecs all have an Intake camshaft and an exhaust camshaft. Look at the top of your 2.4 engine where the sparkplug coils are -- inside that area of the valve cover look towards the passenger side and you will see 2 wires going to the top of the two solenoids. These solenoids control oil pressure to cam adjusters mounted on the ends of the camshafts. The front (passenger side) of the engine valve cover has two bulges -- those bulges provide the clearance for the cam adjusters. None of the other ecotec motor's valve covers, 2.0 2.2, has these bulges/solenoids/cam adjusters.
Interesting discussion. Quite amazing how complicated a motor acutally is. More amazing is how most individuals, including myself, dont realize the intricacies. I personally have take in a ton of information from reading the forums. Not to say that I have learned much of anything, but there is a plether of information on here to keep most of us busy for days to come. I think I get CVVT, but i dont understand it. Not necessarily looking to understand it, as long as it works. xD
Iceberg
Sep 29, 2015 12:33 PM
