What Is The Diameter Of The Down Pipe
Old Jan 7, 2009 | 02:16 PM
mysickwhip's Avatar
Question What Is The Diameter Of The Down Pipe
I Need To Kno The Diameter Of The Down Pipe On The 2.4 For I Plan On Putting An Electronic Cutout But Have To Find The Diameter So I Kno Which One To Get Thanks Alot For The Help
Old Jan 7, 2009 | 02:59 PM
mike25's Avatar
stock? 2.25"..
Old Jan 7, 2009 | 05:58 PM
justypontiacg5gt's Avatar
ive always thought about an electric cutout. i wonder how it'll sound. it would sound badd if you had a turbo and put the cutout after it.
Old Jan 7, 2009 | 09:48 PM
mysickwhip's Avatar
yea i cant wait it should sound pretty bad ass
Old Jan 7, 2009 | 09:55 PM
Thorin's Avatar
it's supose to be 2.5 and 2.25 just before the muffler
Old Jan 9, 2009 | 12:00 PM
Red07SSNA's Avatar
This info has been printed before and it is false...I'm in the middle of installing a LSJ DP on my 2.4L and it is not going well.
First, my 2.4L Auto DP pipe is 2" OD! While the LSJ pipe is larger - 2.5" - it is crimped at the ends down to a 2 1/8" ID. The Cat is nearly twice as big on the LSJ DP than my 2.4L DP -- and it is resting on the sway bar!!!! I need to find out if the LSJ sway bar has a different bend under the Cat. The LSJ DP is also shorter in length -- my Cat-Back exhaust is now pulled forward and jammed against the underside of the car....now I have to modify to make it work...
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
717ssbalt
Oct 2, 2015 04:01 PM
z28addiction
Sep 28, 2015 12:03 AM
