What should i do???????????
just got my 06 cobalt ss 2.4 automatic i put alarm on it and tinted the windows but what would you recomend i do for more power. I want to keep the stock exhaust so any help would be appercaite please let me know what i should do and what i can expect? Thanks
That should net you an easy 20-30 whp.
Well... my list is pretty much the same, but I'll throw it in here too.
Injen CAI, Big Bore throttle body from Saturn Motorsports, GMPP Exhaust Manifold... all of those can be had for less than $300 a piece. Name brand exhausts can get pricey... but you can probably get a local shop to fab you one up for $300 or so.
Hope this helps.
Hope this helps.
Originally Posted by sneaky
Short ram intake, lightweight crank pulley, ECU tune from Vector Motorsports, stock exhaust has to go for better gains (magnaflow or corsa), larger TB, ported heads, GMPP Exhaust mainfold.
Originally Posted by CleanNFun
To me a bigger tb is stupid, unless you have the supercharged model. With the bigger size you are reducing velocity for volume. Unless you have something pushing more air in to make up for the velocity loss I do not really see the point : /. Would definetly not be a first mod to say the least. Correct me if im wrong
man whatever you do get an intake first.. that thing has really woken up the engine. Tonight i went for a ride, after filling up with gas i had to merge on the highway. oh man what a good launch i had, and i didnt even floor it.. can anyone estimate what our 0-60 time is.. i would say 6.9-7 sec for the manual and 7.5 for the auto?
Don't know your exact reasons for wanting to keep the stock exhaust, but if you're looking to make power, the air flow through the motor is key. Intakes help get air into the cylinders but without swapping the exhaust its just a major bottleneck in the system and you'll never see the full potential of your mods.
I'm saying bigger TB b/c the CAI should provide enough extra velocity to make up for any loss. The SMS TB is just a slightly overbored factory unit... it's not a huge difference... but I figure every little bit counts.
SNOBIRD,
Get yourself a Cold Air Intake or Short ram. TurboTech, or Modern Performance - both supporting vendors can take care of you. Remember to re-set the ECU after installling. (Unplug battery for about 15 minutes.) I just did an Injen on mine - will leave as the short ram. Install of short ram is pretty easy.
From there I really think your best bang for buck is ecu tuning. (Do a search.) I am seriously thinking of this. I would not bother with a header unless you are going to do a cat back as well.
Have fun.
- w
Have fun.
- w
How much power are you looking to gain? How much money are you willing to spend or invest?
Everyone can spit out a bunch of modifications but the fact is no one knows what you want or expect out of your car. Untill you can answer those questions, no one can seriously point you in the right direction. For all we know, you want 250 HP and people are telling you to get an intake. See my point?
Not trying to be harsh but trying to be realistic because I've been there and done that. If I could start over, I would have gone straight to boost because that's what I ultimately wanted.
I will agree about the exhaust...supplying more air and not opening it up the exhaust system to a reasonable size (I recommend 2 1/4" diameter) will keep your performance down.
2. Increasing the size of the ports and not changing the camshaft profile to support the bigger volume isn't smart.
3. Putting a bigger exhaust manifold on and leaving the rest of the exhaust system is near pointless. The smallest part of your exhaust system really determines the size of your exhaust system. His stock exhaust system after the header will restrict the exhaust flow and still take away potential power gains.
Originally Posted by davenportdesigns
please do the CAI instead of the SRI for your intake if you go with the inken. the flow is better and you get better performance.
The flow of air will be the same if the piping size on both the intakes are the same and the filters are the same (which in most cases they are because most companies use K & N).
They will perform the same. Don't believe the gimmicks.
Originally Posted by Brandon97Z
intake exhaust and ecu tune will net you about 20hp at the wheels its self. and can be had all together for under $1000.
Even if this did give 20 WHP to one person, it's not gauranteed to do so with someone else.
Thank you NKHK for that enlightening sting of posts. As i said in my post.. an intake HELPS get air to the cylinder, i didnt say that was the only thing between the air and the cylinders.
and you're correct.
