where does the .4 come from ??
Old Jul 12, 2006 | 02:42 PM
Serpico's Avatar
compared to the supercharged version, is it bore or stroke?
as of this moment its not listed on the chevy website
http://www.chevrolet.com/cobalt/specifications/
Old Jul 12, 2006 | 02:47 PM
SS33's Avatar
^^Both, search around, someone posted the bore and stroke of all 3 (2.0, 2.2, 2.4)
Old Jul 12, 2006 | 02:48 PM
sushidog's Avatar
According to GM's website:
2.0l - bore 86mm, stroke 86mm
2.2l - bore 86mm, stroke 94.6mm
2.4l - bore 88mm, stroke 98mm
Here's the link:
http://media.gm.com/us/powertrain/en...html#chevrolet
SS33's Avatar
Good man Sushi,
All of the difference is in the cylinder liners and internals though. The core block is identical across the board
Old Jul 12, 2006 | 02:52 PM
RpSS4844's Avatar
I assume you are talking about 2".4" liter vs. the 2.0 liter in the SS. If this is the case, it is just the displacement of the motor 2.0 = 122 cubic inches compare to the 2.4= 146 cubic inches.
**if you want to get technical 2.0L=122.04749 Cubic Inches
2.4L=146.45699 cubic inches.
Simply put the 2.4 is slighly higher displacement engine than the 2.0. I dont know for sure but it probably has a slightly lareger bore and slightly longer stroke, or a combination of same bore larger stroke, larger bore same stroke. hope this helps.
^^nevermind the question of the bore size has been answered!!!!!
Old Jul 12, 2006 | 10:02 PM
avro206's Avatar
Chevrolets crappy US website at its finest!!
