wheres a vacuum line to seafoam?
Old May 21, 2010 | 05:51 PM
StevoElSupremo's Avatar
like it says, I'm going to seafoam it but I dont know where the vacuum line is to use on 2.4 enigine.
Old May 29, 2010 | 05:37 AM
ChevyBoi89's Avatar
never looked. would like to know as well
Old May 29, 2010 | 12:18 PM
slobalt08's Avatar
on the bottom of the intake mani under the tb you cant miss it its the only tube on the bottom going into the intake mani
Old May 29, 2010 | 12:37 PM
BigSid81's Avatar
not sure where it is on the 2.4, search the how to forum.........maybe it's similiar to the ss/sc??
this is the thread for the ss/sc
https://www.cobaltss.net/forums/show...hlight=seafoam
maybe its kinda the same, sorry if it doesn't help
Old May 29, 2010 | 11:11 PM
I actually think I know what you're talking about I think I've seen that hose.
well I know what I'm doin tomorrow
should i do a how to with pics while I do it?
Old May 30, 2010 | 01:46 PM
slobalt08's Avatar
yeah
Old Jun 7, 2010 | 04:29 PM
Turbo06Sedan's Avatar
Look for a black rubber hose, coming from the intake manifold..(the big black thing under your throttle body).
Pull it off on one end. Start your car. if its sucking in air..its a vaccuum hose..
If its leaking some sort of fluid... You pulled the wrong thing, as there shouldnt be any sort of liquid in your intake manifold.
Old Jun 7, 2010 | 04:35 PM
Zero6LS's Avatar
i put it straight into my gas tank. i think it works well
Old Jun 7, 2010 | 04:39 PM
Do_WorkSS's Avatar
correct me if im wrong, but isnt seafoaming when you have white smoke coming from the exhaust?
Old Jun 7, 2010 | 04:40 PM
eh it works ok there.. probably wont even notice though, the best places are in the crank case and in the Vac... I seafoamed the Crank case and during the oil changed all this Grimy **** came clumping out.
After doing it in the Vac it Idled nicer and had a TAD more pep...
Old Jun 8, 2010 | 04:19 PM
slobalt08's Avatar
at what mileage should i use this stuff
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
