Wiring Diagram for using LSJ TB on 2.4
Old Mar 4, 2010 | 05:27 AM
  #51
Beck's Avatar
Originally Posted by senior_brown
if ur sc'd the lsj tb should have been used
what he said
Old Mar 4, 2010 | 05:32 AM
  #52
CordiaDOHC's Avatar
This is an old thread and it needs to be said the wiring diagram provided most likely will not work on 08 2.4s.
And at last word ZZP said their 2.4 wiring harness and adapter plate didnt work for 08 2.4s either.
Old Mar 4, 2010 | 08:37 AM
  #53
DCOBALTSS's Avatar
ok so it wont work.. damn it.. is there any one who has a 2008 2.4 supercharged here???
what should i do? i want to use the lsj tb because there is really significant hp with it..
Old Mar 4, 2010 | 02:00 PM
  #54
Beck's Avatar
you just have to rewire it.
Old Mar 4, 2010 | 03:15 PM
  #55
CordiaDOHC's Avatar
What he said. You can just rewire it but the wiring would be different from whats been posted to my knowledge. Though ZZP may have something for the 08s now due to their sc release recently which uses the LSJ throttle body. And it shows availbility for 08s.
Old Mar 5, 2010 | 12:53 PM
  #56
Fishers24's Avatar
is it pointless to do a tb and injectors on a n/a setup with just a intake and exhaust or should i just wait 4 my supercharger when ever i can afford that lol
Old Mar 5, 2010 | 04:12 PM
  #57
pat_07ss's Avatar
injectors would be pointless, you wouldn't gain anything from there since your stock injectors are not maxed out!
tb could be worth it if you have a 3'' intake; i personally have one (Rebel 3'' intake, LSJ TB + ZZP adaptor plate, full exhaust) and I like it
I had to get retuned to prevent my car from idling at 2000 RPM though
Old Mar 6, 2010 | 08:18 AM
  #58
DCOBALTSS's Avatar
i think i will contact zzp and ask them if they sell the harness alone for lsj tb to le5...
bcause they have the harness when you buy the adapter for the 2.4 manifold for the lsj tb they come with the harness
Old Mar 6, 2010 | 01:42 PM
  #59
Beck's Avatar
just wait. you have to have the injectors and tb tuned anyways.
Old Oct 29, 2012 | 11:33 PM
  #60
06Cobalt2.4's Avatar
I just want to clarify really quick..
To swap the LSJ throttle Body for the LE5 throttle body, in
2005 and 2006 LE5 Throttle Bodies have 8 pins, and need to be converted to the 8 pins of the LSJ
whereas
2007, 2008, 2009, and 2010 LE5 Throttle Bodies have 6 pins, and need to be converted to the 8 pins of the LSJ
Is the above correct?
Old Oct 29, 2012 | 11:39 PM
  #61
chevygirl2006's Avatar
theres no le5 2005,2009,2010
the le5 tb in the 2006 and 2007 i think are 8 pin. so theres no converting.Its plug and play
the newer le5 in 2008 is a 6 pin so you will have to do rewiring.
Old Oct 30, 2012 | 12:33 AM
  #62
Well the thing is, I'm trying to avoid buying a $39.99 wiring harness if I don't have to.. Maybe this is a stupid question, but would I just be able to cut, splice, connect the wires together, tape and insulate with vaccuum hosing?
Old Oct 30, 2012 | 01:08 AM
  #63
No idea
Old Oct 30, 2012 | 08:19 AM
  #64
Verbatim's Avatar
If you are going to get into modifying VERY IMPORTANT wiring like a throttle body, map sensor, hell everything on these new cars. You need to know how to solder connections properly.
Cut wires, strip back, tin exposed wire, slide heat shrink over wire, strip wire on other side, tin, heat up both tinned wires, make sure no excessive solder exists, lightly tug on wires to verify proper joint connection, slide heat shrink over exposed joint, heat, the end. move on to next wire
Old Oct 30, 2012 | 12:04 PM
  #65
Thanks Verbatim
Posted from Cobaltss.net App for Android
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
