would this turbo work on my 2.4? and what else do i need?
yes i am a noob and i dont know anything about turbos but i really want to get this one. Im going to part this out b/c it will be cheaper as some ppl say. Now what else do i need besides what is in the linkvvvvvvvvvvvvvvv
GODSPEED T66 .48 Trim Turbo 550hp COBALT IMPALA SS S13 - eBay (item 380323215703 end time Mar-16-11 21:30:31 PDT)
well your an 06 le5 so you already have some forged internals. also the 4t45 can handle quite a bit of power. you would need the turbo, a manifold, oil lines, charge pipes, intercooler, injectors, new intake, tune and probably more but your working off a pretty good platform. you would have some lag w/o cams but you should be good to 15 psi. you could easily make 300whp with that 3076
depends on how you want to do it. if you have patience, time, and good craftsmanship then piece together a kit. if you have hella money and want a kit that will bolt up with no problems, buy the zzp kit.
if you do piece together one, i would start with this:
https://www.cobaltss.net/forums/part...-parts-242274/
when i was gna turbo my 2.2 i had an entire parts list top to bottom that i checked off when i got something. i have since thrown that list away for obvious reasons
