ZZP Midlength Check Engine???
Old Jun 15, 2011 | 10:23 AM
newt's Avatar
Originally Posted by olivecj
nope it'll trick the sensor into thinking the air fuel ratio is correct. you still need a tune though in my opinion to get the most out your mods.
The defouler goes on the post cat O2 bung, not the pre-cat.
The only thing the post cat O2 does is make sure the cat is working properly.....if you put a high flow cat on or remove the cat, the post cat O2 sensor will think something is wrong with your Cat and trip the CEL.
This has nothing to do with performace, hell even the pre-cat O2 doesn't have anything to do with performance at WOT.
Buy the header, buy a defouler....done.
Old Jun 15, 2011 | 10:26 AM
zerosk8ter83's Avatar
just disconnect your battery and reconnect to make the cel go away
TurboTechRacing
Oct 27, 2015 07:58 AM
dieGone
Sep 23, 2015 10:20 AM
n20saturn
Sep 21, 2015 01:50 AM
Fearedbynone
Sep 4, 2015 10:24 AM
