ZZP Preferred Exhaust Diameter?
I'm gonna buy an exhaust system from ZZP I've decided, but now I'm curious with which diameter piping should I go? 2.5" or 3"? Is there a noticeable difference between the two? As for HP and MPG, what would be the best? Also, there are 2 header choices, long-tube and mid-length. Mid-length offers 1.75" dia header pipers while long-tube is only 1.5" I believe.
Besides the header, there is the entire cat-back exhaust still thats again, 2.5" or 3". I think I'd rather go with either a full 2.5" or full 3", but is it better to mix and match the 2 diameters? I'm used to diesel esxhausts where we wanted to try to max the diameter as soon as exhaust exited the turbo, but does the same rule apply for gas Balts that are NA?
I'm stuck and need some advice from those who have different size exhausts!
Another question that I have would be concerning the extra bung for the AFR sensor. Is that a good idea to order and install as well? Say I order a header package with the added bung option, will it come with a plug for now until I can install an AFR guage? Or will it just be an open hole for now?
Thanks
I bought the 3" Long tube header and downpipe package from ZZP, and then their 2.5" Cat back exhaust. Sounds great and improved HP considerably. I agree with what hhrfreek said also.
Yes, If you were to order from ZZP, you can choose to have the downpipe be able to bolt up to your stock exhaust. As for the diameter of the exit it would depend on if you are going to stay N/A or not. If you decide to go turbo, then I would say 3" all the way, for supercharged, my setup works great, but there are many other combinations that will work too.
Stock exhaust will bolt up if you select the bolt in option. Figure out if your going SC or TC before you pull the trigger on the header because they will not interchange. If you plan to go SC then get the header now. If you plan on going TC then just get a cat back now because your TC setup will involve a different header/dp.
Get the extra O2 bung. You will need wideband for tuning. If you are just bolting it up to a stock car, just get a plug for the extra bung until you're ready to tune or you have your wideband.
If you are going to go turbo, dont get a header. you wont be able to use it on a turbo setup. if you plan to stay NA or supercharged then get the Longtube header to a 2.5 catback. that will flow more than you will ever need. If you are going turbo, just wait and buy a 2.5 or 3 inch catback when you get the turbo. just my $.02
I suppose this really goes back to my very first "Welcome to css.net thread". For where I'd like to be, power wise, I'm thinking anywhere between 250 - 300 whp will be where I want to be. I don't mind investing a lot of money into my car, but I don't want to make it a dragster.
The forced induction kits ZZP offers seem legit, and I see a lot of people who went with their kits and love them. The difference between SC and TC is noteable, but what path would lead me to 250-300 better?
I think I'm leaning more towards an SC setup. I know a turbo would be pretty awesome, but it would end up being too much in the long run for me. Now I just need to save the fundage for the entire kit and figure out details on tuning.
SC will make it a lot of fun. You'll be happy. If you go with a 3.1" pulley/header/downpipe you will make ~230whp. To get into the 250whp range you will need a clutch. Mine started slipping at 250. You should be able to make 250whp with a 2.8/9". If you get the zzp kit go with the stage 2 kit right away so you start with 60lbs inj and a 3.1. They do have a kit tune, but a custom tune is much better.
You can send them your ecm or I think you can exchange ecms. Use their tune if you have issues finding a shop to tune you. A custom tune will be quite a bit more, guessing $350+ so keep that in mind.
Trifecta is an option. Also if you pick up hpt used and find a good tuner on CSS to remote tune that may be your best option.
Buying the ZZP Mid-Length head/catted downpipe combo right now. 1.75' primaries, extra bung for wideband and 2.5' exit flange to run my stock exhaust for now. <--- Hopefully this will light a fire under my butt to get going on an SC kit.
z28addiction
09-28-2015 12:03 AM
