zzp s/c or zzp t/c 2.4 kit? pros n cons?
I was looking at zzps stage 2 supercharger kit and it was just under 3 grand. The t/c stage 2 kit was also just under 3 grand(without installation and tune though). Which one would be the better one to get? which one would produce more power. ZZP claims that that the stage 1 s/c kit makes 225hp and stage 2 make 25hp more so 250? What does the stage 2 t/c kit do in hp? Any other kind of helpful info about the zzp kits would be great!
I suggest turbo. Its easier to control boost levels. And you also have the capability of yielding more power compared to a blower imo. I also feel that its a more simple install.
and stage 2 t/c kit does about 260s ive been told, stage 3 is about 285 i was told by Tim who works at zzp. im going to get stage 3 t/c kit and le5 performance cams and ecotech #82 valve springs after that and a tune ill be around 320whp he said. just if you wanted that kind of power.
stage 3 s252 3 inch exhasut, pisses me of fthat cams are on back order, make sure you email them to ask if parts are in stock before you order, i got the run around for about a month before my turbo kit shipped, and the run around agai nfor a mont hon the le5 cams.
On 13-14 psi I made 377-377 on a awd mustang dyno which my buddy's Evo that goes 10.0's at 143 made 480 2 weeks after it made 600 on buchurs dyno so my car on a dyno jet is for sure in the 400's
