2.0L Engine Build
2.0L Engine Build
For those who know what they are talking about. I am one of the people that have blown the motor and is the process of rebuilding. I have to a couple of quick questions regarding rebuild and boost applications. Before I start if you plan on flamming or start post wars please leave the thread. Here is my sitiuation last winter installed 2.2L cometic headgasket instead of the 2.0L because at the time the 2.0L was not in production and purchased head studs. Well now the motor shot due to whatever the flaws are, pistons, fuel starvation, heat etc.... I ordered new pistons. Went with 10:1 because of the headgasket dropping the compression down to 9.5:1 which brings it back to stock compression. Right now I am trying to decide which route to go far as pulley setup:
1.keep the headgasket which is perfectly fine and go with a whatever pulley that will work to maximize the power
2.get the 2.0L headgasket which will raise the compression to 10:1 and run a larger pulley
Any thoughts or comments in general regarding builds for the LSJ. I would like this thread to be an informative and useful resource for people that are the same position or will be in the same position down the road.
Thought I would bring this thread back to life. I would also like to know. I always felt that low compression pistons would work great with the LSJ. Maybe go as far as 8:1 so you can run even more boost. Maybe just keeping the stock compression would also work nice since its strengthing everything. What is this talk about compression changing with head gasket?
from what I have read is that since the 2.2L headgasket is thicker than the 2.0L it lowers the compression about a .5 So theoreticaly by having a 2.2L headgasket would drop stock down to 9:1 instead of maintaining 9.5:1. Therefore the 10:1 pistons I bought now should have a compression ratio of 9.5:1 with that headgasket. I only went with the 2.2L because that was the only headgasket available at the time when I wanted to switch it out asap because people at the time were starting to blow the stock headgaskets with 20lb of boost or more. After I installed it then they released the 2.0L and I wasnt about to tear the motor back apart again to change it lol since the only difference is the thickness.
Well basically a higher compression ratio helps improve off boost performance. Since an Eaton supercharged makes boost almost instaneously, I would run a lower compression ratio and help make up the difference with more airflow.
9:1 sounds like a good comfortable number to run.
The thicker head gasket will effectively increase your combustion chamber volume which in turn will lower your static compression ratio.You did not mention what piston manufacturer you will use so I'm unsure if your pistons will have a dome or not.I am not a fan of thicker head gaskets especilly stock compositin types as they tend to blow easier.If your pistons have a dome I would have your local machine shop shave them the desired amount to produce a combustion chamber volume,including deck height and compressed gasket thickness to give you the desired 9.5 compression ratio using the LSJ gasket.You also didn't mention what you plan to use for camshafts.If you are grinding something custom the amount of overlap comes into play as a lot of overlap will bleed off cylinder pressure.Depending on your budget,my choice would be to use the GMPP cylinder head that is cut for O-Rings and the gasket set that goes with it.
Just my opinion of course,good luck on the build keep us posted
Stock compression is perfect for this motor. Ever wonder why no one makes low compression pistons for the LSJ? The ecotec is an extremly knock resistant motor, meaning you can run it with lots of boost and heat, and still get minimal if any detonaton. In my experience this motor gets less detonation than almost any other motor I've worked with. The head design is very good and the combustion chamber does a good job of eliminating hot spots.
Go with the 10:1 and the cometic gasket for the lsj. The problem with the m62 is when you run a 2.5 pulley you are over spinning it and it looses efficency. Bump up the compression and run a 2.7 pulley cooler IAT 2's more timing less blower drag on the engine.=More power.
Side note: The top fuel dragsters blowers take 300 hp to turn.
I agree. Higher compression, supporting mods, larger pulley, and cam work will make you a lot more efficient and greatly cut down on the heat problem. Remember, the cooler your charge, the denser the air. Meaning you can move more air mass with a lower volume (and thous lower psi), with less risk of blow ups from heat. Plus you won't heat soak near as easy and the car will cruise easier since it will be making more power while not under boost.
The blower looses efficiency not with speed, but with boost. The more boost, the less efficient. If you could spin the blower with a 2.6" pulley and only make 15-16 psi the blower would be back in its efficiency range but with the CFM of a 2.6". Thats why I'm doing extensive head work on mine, my goal is less than 17 psi with a 2.6" pulley, if I could get it down to 15 psi the heat would almost not be an issue with all the cooling mods I have.
They take 200-300 hp to turn the blower depending on the track.
Last edited by Blown 4-banger; May 12, 2007 at 05:47 PM. Reason: Automerged Doublepost
im hoping porting my blower will drop my boost levels enough unfortunetly head work, is august for me, when my spare head gets done, god i hate long line ups for head work sometimes but its worth it
Porting your blower won't really reduce your psi that much. Without reducing the amount of air your shoving into the engine, the only ways to reduce the psi are:
1) Cool the air
2) Increase engine flow
3) Enlarge compression chamber size
1 & 2 are the way you want to go. 3 will just mean you'll hit the high point psi a little later in the rpm band.
1) Cool the air
