2.0L Engine Build
I too see only 15-16psi with a 2.7" so you sound similar. My car runs fine and is FAST, that's all that matters.
am i understanding this correctly? upping the compression and dropping the boost produces similar power to high boost and low compression? that would seem like a good idea to me since i wont overspin the blower........
IMO you gonna be better off running more boost and less compression. Why? Because with lower compression pump gas is much more accepted by the motor. 10:1 compression with boost is kinda iffy with pump gas (at least in AZ).
well thats sucks on the gas, well i will probably do the 2.8 and hopefully next weekend get it dynoed tuned, and crossing fingers it will not blow up on the dyno like it did last time. I pretty nervous about it going on the dyno.
The blower looses efficiency not with speed, but with boost. The more boost, the less efficient. If you could spin the blower with a 2.6" pulley and only make 15-16 psi the blower would be back in its efficiency range but with the CFM of a 2.6". Thats why I'm doing extensive head work on mine, my goal is less than 17 psi with a 2.6" pulley, if I could get it down to 15 psi the heat would almost not be an issue with all the cooling mods I have.
That sounds like a good plan!
patooyee
Oct 1, 2015 01:07 PM
