2.0L Engine Build
Old May 29, 2007 | 11:58 PM
Psykostevo's Avatar
Originally Posted by SSMOKEM
Dumb question.... when you mean "make 15-16psi" with a 2.6, do you mean at redline or WOT? Because I'm seeing around 15psi with my 2.6 I may be wrong at where I'm seeing it though? I'm sure I sound like a complete tard, sorry
I too see only 15-16psi with a 2.7" so you sound similar. My car runs fine and is FAST, that's all that matters.
Old May 30, 2007 | 12:03 AM
BlueSSupercharged's Avatar
i dont know if it was said or not but the stock compression on the 2.0 is 9.5 to 1 not 10 to 1.
Old May 30, 2007 | 01:06 AM
Blown 4-banger's Avatar
When did we say it was 10:1??? I'm pretty sure everyone knows it 9.5:1. Hell I even know that the combustion chambers are 52 cc (CC'd the combustion chamber at work today)
Old May 30, 2007 | 01:21 AM
Travi-ss-'s Avatar
am i understanding this correctly? upping the compression and dropping the boost produces similar power to high boost and low compression? that would seem like a good idea to me since i wont overspin the blower........
Old May 30, 2007 | 11:37 AM
Non of us are over spinning the blower. The blowers max constant RPM is 16000, and short burst is 20000. At 7000 rpm and a 2.5" pulley the blower is spinning at 16,500 rpm.
Old May 30, 2007 | 11:41 AM
blown06's Avatar
do you happen to know the power difference say 9.5:1 runnign a 2.6 and 10:1 running a 2.8? Are they going to be similar in power wise?
Old May 30, 2007 | 11:50 AM
IMO you gonna be better off running more boost and less compression. Why? Because with lower compression pump gas is much more accepted by the motor. 10:1 compression with boost is kinda iffy with pump gas (at least in AZ).
Old May 30, 2007 | 11:54 AM
blown06's Avatar
is it because of the heat out in AZ?
Old May 30, 2007 | 11:58 AM
That plus the shittiest bottom of the barrel 91 SHITane gas in the country
Old May 30, 2007 | 12:02 PM
blown06's Avatar
well thats sucks on the gas, well i will probably do the 2.8 and hopefully next weekend get it dynoed tuned, and crossing fingers it will not blow up on the dyno like it did last time. I pretty nervous about it going on the dyno.
Old May 30, 2007 | 12:39 PM
  #36
zinner's Avatar
Moderator Alumni
Originally Posted by Blown 4-banger
The blower looses efficiency not with speed, but with boost. The more boost, the less efficient. If you could spin the blower with a 2.6" pulley and only make 15-16 psi the blower would be back in its efficiency range but with the CFM of a 2.6". Thats why I'm doing extensive head work on mine, my goal is less than 17 psi with a 2.6" pulley, if I could get it down to 15 psi the heat would almost not be an issue with all the cooling mods I have.
That sounds like a good plan!
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
jas09ss
Sep 26, 2015 01:06 PM
