2.4 -> 2.2 car
Old Apr 24, 2009 | 03:08 PM
pessimism's Avatar
2.4 -> 2.2 car
Has anyone dropped the 2.4 into a 2.2 car? I'm assuming it would require motor, ECM, harness and that everything else would bolt in unchanged?
Old Apr 24, 2009 | 03:12 PM
ChevyRockstar's Avatar
the money you spend on it , your better off trading in
Old Apr 24, 2009 | 03:40 PM
HunterKiller89's Avatar
motor, ecm, harness, ABS sensor, DIC, Gauge cluster, airbag sensor, etc
Old Apr 24, 2009 | 04:21 PM
pessimism's Avatar
How does the airbag system interact with the engine?
Old Apr 24, 2009 | 04:24 PM
ssyellow's Avatar
thats a lota money for like what 25 more hp? just do some bolt ons I would think.....
Old Apr 24, 2009 | 04:25 PM
D4u2s0t's Avatar
Nobodies done it because it's not worth it. if you're going to go through the hassle of an engine swap, why put one in that makes barely any more hp, and doesn't really have much more potential. Just not worth it.
Old Apr 24, 2009 | 04:30 PM
eurochevy's Avatar
ya not really worth it, might as well get a diff car or just turbo the 2.2 or w/e..ends up being about the same as the 2.4 anyw ay
Old Apr 24, 2009 | 04:32 PM
ZeeBee's Avatar
there is nothing wrong with the 2.2 in fact the block is thicker/stronger then the 2.4/2.0, forge the guts and fi
Old Apr 24, 2009 | 04:49 PM
stenguyen1's Avatar
why don't you just do a lsj swap if you gonna spend all that money to get a 2.4 in your 2.2 car
Old Apr 24, 2009 | 05:09 PM
_UnLiMiTeD_'s Avatar
The thickness of a block is irrelevant at these power levels, the block itself is fine for any horsepower level you can throw at it until you start building it into a full drag car. Also the internals on the LSJ and LE5 can handle more power because they're forged.
So in the end, to do a turbo build thats over 250whp, its cheaper on a 2.4 or 2.0 block. The 2.2 needs internal work to be reliable above 250whp and that starts to get expensive
Old Apr 25, 2009 | 01:00 PM
ZeeBee's Avatar
your always on my ****, i notice...
Old Apr 25, 2009 | 03:52 PM
it doesnt. But it interacts with the ECM, which interacts with the engine. New engine requires new ECM which requires new everything else that attaches to the ECM
basically...motor swaps just aren't done on our cars
Old Apr 25, 2009 | 05:15 PM
For what? I have nothing against you, just stating facts, its not persnal, just the truth
Old May 17, 2009 | 06:39 PM
Turbo06Sedan's Avatar
the 2.2 has more aftermarket support in the sense of internals.
the 2.4 makes more power per of boost than any other cobalt motor due to the higher compression & displacement
chefhhr
Oct 26, 2015 10:36 PM
OrngBalt
Sep 16, 2015 07:45 PM
BettyBlue2.2
Sep 10, 2015 08:49 PM
matthewwalsh1994@gma
Sep 10, 2015 10:48 AM
toledobalt
Sep 2, 2015 07:04 AM
