2.4 -> 2.2 car
Nobodies done it because it's not worth it. if you're going to go through the hassle of an engine swap, why put one in that makes barely any more hp, and doesn't really have much more potential. Just not worth it.
So in the end, to do a turbo build thats over 250whp, its cheaper on a 2.4 or 2.0 block. The 2.2 needs internal work to be reliable above 250whp and that starts to get expensive
The thickness of a block is irrelevant at these power levels, the block itself is fine for any horsepower level you can throw at it until you start building it into a full drag car. Also the internals on the LSJ and LE5 can handle more power because they're forged.
