2.4 crank 2.0 block???
It would work, but the 2.4 block is also a gen 2 block like the 2.0 and is just as strong, so unless all you have is the 2.0 block you would need custom pistons to work with whatever rods you decided to go with. The stroke would change the piston pin location. You would need a piston with the same pin location as the 2.4 but the same bore as the 2.0. This would all change if you use rods with a different length than the 2.4.
Why not a complete 06/07 LE5 bottom end swap? Make sure it is strictly those two years otherwise you get junk rods with it, and make sure it has the oil cooler option. You just have to worry about clutch/flywheel options
Sep 28, 2015 12:51 PM
