Anyone Running ZZP Cams?
Im looking at getting some cams and just wanted to insight on them. Im between stage 2 and 3 but i want the car to still be drive able as it is my DD. Anyone running stage 3?
The only reason you should go with the stage 2 cams is because it allows for a more streetable powerband. If you read on ZZP's website the stage 3s move the powerband much higher than anyone would be able to use on a DD setup.
The question I never see answered with the stage 3 is; "where is it giving up the power?"
"moves the powerband" insinuates a loss of lower rpm power, but where? how much?
for example, if its below 2000, but everything from 3 to 8 is still an increase over stage 2, then yeah, I might never see 95, but I would still have gains, and might be able to stomach the loss at 200 and below.
but without a stated powerband, or dyno info, or something, who can make an educated decision?
I've seen the dyno comparos between stage one and stage 2,but never a comparo of stage 2 and stage 3.
anybody ?
anybody ?
anybody ?
anybody ?
