balance shaft delete kits
Old Jul 11, 2007 | 08:48 PM
sunfirejoe's Avatar
has any one decided to go with a balance shaft delete kit on there lsj, i know theres a couple that have in jbodies on there 2.2 just seeing if u have any do's or dont's.
mine are pressed in now, so no more balanc e shafts for me, now time to get my car runnning
Old Jul 11, 2007 | 09:43 PM
Witt's Avatar
I'm running neutral shafts, but not much of a difference in installation compared to stockers.
I'm interested in how you "pressed" them in. The only issue I know of when doing a full delete is making sure you plug the oil holes or theres a part of the engine that will be starved of oil (can't remember which).
Old Jul 11, 2007 | 09:48 PM
lnf08ecotec's Avatar
Arent the neutral shafts basically a balance shaft delete...bc they become neutral(?)
Old Jul 11, 2007 | 09:49 PM
Witt's Avatar
No its a replacement shaft thats not counterweighted. Hes talking about removing them entirely.
Old Jul 12, 2007 | 02:08 AM
sunfirejoe's Avatar
removed, u have to press a sleeve into the back part of the the oiling for the balance shafts so u keep oil pressure up, time will tell, i know it removed a lot of weight from the motor
Old Jun 29, 2009 | 06:41 AM
STS2/SS's Avatar
What did you use to press them in?
Old Jun 29, 2009 | 06:54 AM
OneCOLDBIZL272's Avatar
when i built my LSJ, i did the balance shaft delete their entirely gone, you feel a ton of vibrations but are easily over looks cause of the performance gains
Old Jun 29, 2009 | 03:27 PM
bolus's Avatar
The performance gains are not great ~10hp. I did the GM racing kit, bushings were made and pressed in by my engine builder. There is a UK forum that showed how to get the bushings in without a press. A friend of mine did it that way
https://www.cobaltss.net/forums/show...=balance+shaft
http://www.z22se.co.uk/forum/viewtop...t=5895&start=0
(check the dyno towards the end that showed no gain)
Old Sep 29, 2009 | 04:50 AM
mkriebs's Avatar
I am interested in a BSD for the LNF. I would assume its the same as the LSJ. Just a couple Q's. Is this permanent, since the bushings need pressed in?
Old Sep 29, 2009 | 10:24 AM
freakta's Avatar
whats the gm race kit?
Old Sep 29, 2009 | 01:51 PM
HunterKiller89's Avatar
IIRC the part that blocks off the oil passages is .040 oversized, so it needs to be pressed in.
Supercharged06SS
Dec 11, 2022 04:47 PM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 28, 2015 12:51 PM
