building the engine, anything else i may need?
Old Mar 14, 2009 | 02:19 PM
Nussle's Avatar
im about to order these things
-Diamond pistons w/ rings, both coatings, standard bore and stock bompression
-Supertech valves
-Supertech 78lb valve spring kit
-Cometic head gasket
-ARP head studs
is there anything that im not thinking of that i need to finish this build?
Old Mar 14, 2009 | 03:18 PM
HunterKiller89's Avatar
most people upgrade the rods while theyre in there, but i suppose it depends on your power goals. You've got all the essentials though.
what are you building the engine to do?
Old Mar 14, 2009 | 04:25 PM
SSdan's Avatar
IIRC, he's just doing a rebuild. His stocker broke.
Old Mar 15, 2009 | 12:36 PM
Smarty Art's Avatar
I assume since your doing a valve and spring upgrade your also going to get cams. I would add neutral balancing shafts to that list if you plan on taking the RPMs into the 8K range.
hacadacalopolis
Oct 28, 2015 06:09 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
