Cooling Down Meth in Freezer before using?
Old Jun 16, 2008 | 05:28 PM
an0malous's Avatar
empty the meth out of my res into a jug, put it in the freezer the night before track day...
wrap the res in foil, and pour freezing cold meth/water in there before hitting the 1/4 mile?
why not?
Old Jun 16, 2008 | 05:37 PM
mike25's Avatar
thatd be interesting...seems like it would work in logic...but who knows
Old Jun 16, 2008 | 05:38 PM
invisible's Avatar
Would it get any colder than it already does though? It already gets freezing but interesting none the less.
Old Jun 16, 2008 | 05:39 PM
an0malous's Avatar
50/50 mix has a freezing point of -50f
so it certainly has the potential to be colder.
Old Jun 16, 2008 | 05:40 PM
invisible's Avatar
Certainly can't hurt to try.
Old Jun 16, 2008 | 05:52 PM
lsjwannabe's Avatar
i was thinking about this to ano...
Old Jun 16, 2008 | 05:55 PM
an0malous's Avatar
no real cost involved, and its certainly not difficult to do...
every single degree cooler that the meth/water is at, is another degree of heat that it will draw out before it evaps.
Im definately going to give it a try.
Old Jun 19, 2008 | 09:32 PM
an0malous's Avatar
jug of boost juice just went in the freezer
Old Jun 19, 2008 | 11:37 PM
sunfirejoe's Avatar
when i ran meth, w/ my fire i just put ice in instead of water while at the track, worked awesome, temps were on average 10 to 20 degrees lower, ofcourse that was after a run, and probably was getting closer to a 90/10 mixture lol
Old Jun 19, 2008 | 11:40 PM
Mr_Slobalt's Avatar
so, is it just regular washer fluid that you can pick up at any gas station or auto store? I've always wondered
Old Jun 19, 2008 | 11:42 PM
invisible's Avatar
Thats actually pretty damn smart........
Old Jun 19, 2008 | 11:43 PM
Cobalt_SSTuner's Avatar
wow, something that simple, i would hav never thought of....
Old Jun 19, 2008 | 11:45 PM
Red2.4SS's Avatar
It will make it harder to evaporate though?!
But I guess in the combustion chamber it wont matter so the colder the fluid the better I would assume!
Old Jun 19, 2008 | 11:46 PM
bigrroberto's Avatar
I should bring a bunch of dry-ice in a cooler from work (can get it free) we could put the coolant in there between runs...
Old Jun 19, 2008 | 11:48 PM
invisible's Avatar
The only thing that scares me about that is a small piece getting through to the pump.
Old Jun 19, 2008 | 11:49 PM
an0malous's Avatar
harder to evaporate is good!
water/meth cools by taking energy from the surrounding air (heat) to turn from liquid to gasseous form.
so by simple logic, if said water meth STARTS at a lower temp....it will require more energy to evap.
not only will that remove more heat from the blower/intake mani, but by doing so, it should allow more to actually make it to the cylinder, and do more cooling there.
at least....thats the theory anyway
Old Jun 19, 2008 | 11:53 PM
lol
just put a jug into a cooler full of dry ice, like putting a beer on ice.
Old Jun 19, 2008 | 11:55 PM
invisible's Avatar
lol
Yea but what about when you actually put it in at the track?
Nevermind, reading < me I guess. lol
Old Jun 20, 2008 | 12:00 AM
ColeJJones's Avatar
Bannned
ever put something extremely hot on something extremely cold??? what happens? it cracks
Old Jun 20, 2008 | 12:01 AM
i'm excited to see the results
Old Jun 20, 2008 | 12:07 AM
an0malous's Avatar
i guess all those people spraying nitrous at -130* must be crackin **** left and right then!
thinky before posty....
Old Jun 20, 2008 | 12:10 AM
"You've just been PWNED!"
invisible's Avatar
have seen people put bags of ice on the s/c with no problems.....
Old Jun 20, 2008 | 12:16 AM
ColeJJones's Avatar
Bannned
just skeptical.
but if you do freeze it how long does it hold that temp til you get to the track? will cool down considerably
Last edited by ColeJJones; Jun 20, 2008 at 12:16 AM. Reason: Automerged Doublepost
Old Jun 20, 2008 | 12:28 AM
an0malous's Avatar
these are all things ill be finding out tommorow
Ill probably take it in my cooler.
ill be insulating the resevoir too, to keep the temp low as long as possible.
plus my kit is trunk mount, which helps ALOT
