Custom ice box
Old Oct 31, 2007 | 12:39 PM
hatrickstu's Avatar
Originally Posted by Evil C
lol They are called Cool cans and hey have been around for ever. You can do your fuel lines with sumpin as simple as a large pill bottle with a hole cut in it for the Fuel line and some silicon sealent around that. Lovely bit of 1950s tech there. the traditional method for air intakes and coolent hoses was to use a coffee can with a hole cut in it and a folded over lip so as not to cut the hoses and the gaps filled with sealent of some sort.
could anyone understand this?
Old Oct 31, 2007 | 02:26 PM
an0malous's Avatar
yeah ive seen this old method before.
you basically just use a can of some sort to surround a line, like your fuel or coolant, and fill that with ice.
its a very cheap quick way to achieve a result, though its not going to work as well as a true icebox, becuase the ice has to conduct the heat through the hose, and it doesnt have long to do it as the fluids move kinda quickly, not to mention they will only be against 3-4 inches of actual hose.
Old Oct 31, 2007 | 02:30 PM
hatrickstu's Avatar
ok that makes more sense. id still MUCH rather have a true ice box though, seems it would be 100 times more effective
Old Oct 31, 2007 | 05:28 PM
Johnny B's Avatar
^or you could install meth & water, or alcohol & water kits on your car. helps cool it down alot and simple to install.
Old Oct 31, 2007 | 05:30 PM
an0malous's Avatar
yeah meth would be good, but at this point i just dont know if im ready to spray things into my engine
Old Oct 31, 2007 | 05:33 PM
Johnny B's Avatar
well im just sparying water now i got 2more lbs of boost and about 10 degrees cooler temps. oo and i wired mine to a rocker switch so its not sparying everytime i get on it, just when its been running a while or when i think i need the extra boost... just my .02.
Old Oct 31, 2007 | 06:02 PM
hatrickstu's Avatar
^^^ have you done some data logging?
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
