DEVL Heat Exchanger,anybody use this
Old Jul 12, 2008 | 02:58 PM
MSHETZ's Avatar
Question DEVL Heat Exchanger,anybody use this
has anyone used a devl he for the ford lightning its the same dimensions as the cxracing one but devl says it is a double(dual) pass, would i need to get a gm dual pass with this or will the he one be ok?
Old Jul 12, 2008 | 03:07 PM
AjSS's Avatar
I honestly cannot find any info on the "devl" heat exchanger that you are talking about, but I will tell you that it being a "duel-pass" means that it is designed where the coolant goes through twice (2 seperate passages) to get more cooling effect, and it is not the same thing as the GM duel-pass that has to do with the aftercooler.
Edit:
I found what you were talking about, its only on ebay, but its exactly what I said before.
Old Jul 12, 2008 | 03:44 PM
MSHETZ's Avatar
ok thank you
DarrenGC
Dec 24, 2021 01:55 PM
Spanky's Monkey
Mar 7, 2016 06:06 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
