dual pass question
dual pass question
Ok i have my 1/2" npt to 3/4" hose barb fitting and my 1/8" npt to 1/4" hose barb fitting. I also have the extra resivoir. My question is what is this .040 orifice? Where can i ifind it? i looked inthe auto parts store by my house and i wasnt able to find anything that fits in the 1/4" hose. Is the orifice needed? Where to i intall the orifice?
Look in the vacuum fittings section of your local auto parts store, it is a universal splice or tee designed to be used with several sizes of hose. You cut off the 1/4"-1/8" sections and press it into the 1/4" bleed line at the NPT fitting end with a screwdriver or similar tool.
Do you think running a 2.9" a dual-pass would be beneficial? I am still stock cooling wise. I don't drive the car hard at all, hardly get wot runs all the way to 3rd gear but I am planning on going to the track in a couple weeks. I was just wondering how difficult it is to do the gm option b. What is the difference between the dual-pass kits you sell and the ones CED sell?
The orifice can be found at any auto store, All it is: A reducer in the Line! They come in a tee with 3 sides & you cut it to get the piece that fits in the Line, Like it shows in the diagram!
The reduction in the line helps keep the pressure up in the main system & it slowly bleeds into the reservoir creating a Vacuum in a sense! The reason you dont want to run without it is if it is just a open 1/4 inch line the pressure in the system will go down & the pump can't handle the extra flow! Thats why you reduce it to create back pressure! Been running it for months now No problems what so ever!
If you are running a smaller then stock pulley the dualpass will help. It helps keep IAT down over multiple hard runs and helps reduce heat soak slightly. The dualpass is not "HARD" to do, but it is time consuming. Make sure you have lenty of hoses so you don't have to make a bunch of runs back and forth from the auto parts store.
Hey man off subject, But you Know I was born in Saint Charles & My Mom still lives there!
Someone out here was talking about doing the dualpass option b sometime soon, if I help them out I will make sure to take pictures for a how-to.
Awesome, thanks a lot. I would greatly appreciate it. Did you buy your endplate from CED or from someone on here? How much do you think it costs to do the full option B verses A.
Here's a close up picture of the "orifice", I already cut the one side and put the missing piece inside my bleed line.
Doesn't matter, the point is to create a smaller opening to slow down the fluid transfer from the top of the intercooler into the bottle.
