E85 Review: Wicked Gets Gets Corn Fed
Old Oct 19, 2009 | 12:06 AM
WickedSS2005's Avatar
**Cliff Notes @ Bottom**I finally felt comfortable with where my 79# injector tune is to try E85. I ran my car as dry as I could, another 32 miles after fuel warning was on. Put 12.2 gallons of E85 in the tank after flashing my base E85 Maf Calibration. And nothing... No spark, no cranking, just lights... HPTuners beta is just that, a beta with bugs. After adjusting some things to get HPT working properly, a re-write got me out on the road. Was fed up and went home for the day.
Friday I drove from Dayton, OH to Apple Creek, OH (189miles/3hrs) and did a little fine tuning. First tank was 24mpg average. A loss of 8mpg Idle is rough on start up for a bit til it got warmed up. Overall driving is smoother and more responsive. That night I revised my tune from the data and loaded it up.
On the way down to the Ohio Meet I filled back up. The cruise down was much better on my gas tank. Dialing in the maf netted me 29mpg, a loss of only 3mpg over premium fuel.
Later that day TennPenn83, friend of mine with a TVS, wanted to run my car, his car, and lsjion's car. Mods are as follows:
WickedSS2005
Injen Intake
Ported M62
2.6" pulley
Garret H/E
79# Lucas Injectors
Pacesetter Header
3" catless exhaust
E85
TennPenn83
K&N Intake
LS4 Throttle Body
TVS
80mm Pulley
ZZP H/E
Dual Pass
Opt B
79# Lucas Injectors
Stock Compression Diamond Pistons
lsjion
2.8" Pulley
42# Lucas Injectors
Full 3" Exhaust
Midlength Header (not sure of brand)
Garret H/E
Ported Head
Results are as follows:
First run, 5o mph: I was in 3rd, others were in second (bad gear choice on my part) lsjion and I were dead even til I got higher in the rpm where I gained 2 cars and TennPenn83 walked us both.
Second run, Wicked vs TennPenn
40mph, second gear for each. Dead even! The ION Redlines have a 17" rim which means they shift sooner than us Cobalts. I'd nose up n his shift, he'd catch up on my shift.
**Cliff Notes and Overall Review**
E85 is WIN! I lost 3-4mpg overall. My timing went from 20* to now 25*. AFR @ WOT is 11.6. Overall the car is more responsive throughout all driving conditions. There is a bit of a rough cold start, but once warmed up the car idles fine and drives great. IMO, the car runs better on E85. Smoother shifts, less jerky entrance/exit of DFCO. 2.6 M62 E85 car is dead even with a stock pulley'd TVS.
Oh, and slight hint of corn from exhaust fumes. If you can do the E85 (availability in your area) I HIGHLY recommend it. I save $6bucks a fill up and lose 30-40 miles per tank. It's worth it for me. I'm never going back to full dinosaur fuel. E85 =
Old Oct 19, 2009 | 12:22 AM
spike's Avatar
nice job. E85 seem to be the way to go!!! thinking bout it myself
Old Oct 19, 2009 | 12:24 AM
06_SIC_SS's Avatar
Meth still does the trick
Cefaln452's Avatar
so really the savings are not that different, they pretty equal out huh tom? and rough starts, do you just mean missing or what till it gets warm? I have the siemens 60# how do they compare to the lucas ones?
Old Oct 19, 2009 | 12:36 AM
Area47's Avatar
Rent me! per hour
go into your open loop warm up fueling tables for the p/n and in gear. ADD fuel to it. looking between 10-15% more over stock numbers.
Old Oct 19, 2009 | 12:37 AM
Cefaln452's Avatar
and that will do what? fix the rough idle?
Old Oct 19, 2009 | 12:38 AM
ColeJJones's Avatar
Bannned
i have a question. once i get bolt ons and tune. ... if i use e85 one day will it be bad, will i gain power, or do you have to tune for it?
Old Oct 19, 2009 | 12:42 AM
Area47's Avatar
Rent me! per hour
warm up = open loop. 02 sensor and mas air need not apply in this mode.
Old Oct 19, 2009 | 12:47 AM
Cefaln452's Avatar
ahh i see. interesting. have you ran it yet area? if so what are your thoughts?
HAVE TO tune for it, and yes you will gain more power
Old Oct 19, 2009 | 12:55 AM
ColeJJones's Avatar
Bannned
so if i just have a reg tune for gas and one day i throw in e85, i wont notice a difference?
Old Oct 19, 2009 | 01:02 AM
Area47's Avatar
Rent me! per hour
e85 and winter time doesn't work well. so i am back on 79's and pump gas. besides, i was out of fuel pump at 6k rpms on the 98lb injectors. in short, yes i have run it
Old Oct 19, 2009 | 01:08 AM
Cefaln452's Avatar
no you'll notice a huge boom and no more go
Old Oct 19, 2009 | 01:09 AM
ColeJJones's Avatar
Bannned
haha, nice
Old Oct 19, 2009 | 01:10 AM
Cefaln452's Avatar
gotcha area.... can i be done fine in winter? or is it just one of those picky deals?
Old Oct 19, 2009 | 01:17 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Nice, Tom. I plan to switch to e85 when I get back. Wanted to before I left, but didn't have the time.
Old Oct 19, 2009 | 05:35 AM
ralliartist's Avatar
who ported lsjion's head?
awesome review, e85 seems like the new way to go, the potential is just too great.
Last edited by ralliartist; Oct 19, 2009 at 05:35 AM. Reason: Automerged Doublepost
Old Oct 19, 2009 | 01:31 PM
lsjion does porting. I have a port coming from Euthanasia
Old Oct 19, 2009 | 03:21 PM
Tennpenn83's Avatar
was my thread not good enough for you, tom? lulz...
WickedSS2005
Injen Intake
Ported M62
2.6" pulley
Garret H/E
79# Lucas Injectors
Pacesetter Header
3" catless exhaust
E85
TennPenn83
K&N Intake
LS4 Throttle Body
TVS
80mm Pulley
CX Racing Dual-pass Heat Exchanger
Dual Pass
Opt B
79# Lucas Injectors
lsjion
2.8" Pulley
42# Lucas Injectors
Full 3" Exhaust
Garret H/E
Ported Head
First run, 5o mph: I was in 3rd, others were in second (bad gear choice on my part) lsjion and I were dead even til I got higher in the rpm where I gained 2 cars and Tennpenn83 walked us both.
Quoted for Driver Mod 2.0, and to not give credit to ZZP for anything on my car.
Last edited by Tennpenn83; Oct 19, 2009 at 03:22 PM. Reason: Automerged Doublepost
Old Oct 19, 2009 | 04:06 PM
^douche. lol
Old Oct 19, 2009 | 04:18 PM
Your thread was from your POV so I made one from my POV. Makes it mroe concrete to have both sides of the story.
Oh, and not my fault you wanted to crank 2nd gear to 6k from the get go of the first run. I stayed in third. So. Driver Mod 2.0 is now obsolete
Old Oct 19, 2009 | 04:22 PM
Tennpenn83's Avatar
got me the win, didn't it? come down here real quick and i'll show you how obsolete driver mod 2.0 is... lmao
Old Oct 19, 2009 | 04:31 PM
the gayness.......ahhhh....
Old Oct 19, 2009 | 04:41 PM
Jordan, I'm not checking out how you handle your stick
Old Oct 19, 2009 | 04:42 PM
^rofl
Old Oct 19, 2009 | 04:47 PM
Tennpenn83's Avatar
don't be jealous now, tom... notice how strong yet smooth my right forearm has gotten
