Ecotec Cylinder 4 wear - common issue problem in performance applications?
Old Nov 28, 2018 | 03:05 PM
steelmesh's Avatar
In my little world, I seem to have noticed a pattern with Cylinder 4 in the 2.4 Ecotecs.
Block 1: Stock and boosted 2006 LE5 block, Cylinder 4 cylinder worn out bad (0.015" over spec)
Block 2: Built and boosted 2015 LEA block, Cylinder 4 has the lowest compression and worst leak down result
Block 3: Stock never boosted 2012 LEA block, Cylinders 1-3 measure 0.0006" wear over spec, Cylinder 4 measures 0.0010" wear over spec
Could this be a problem with block cooling around Cylinder 4? Anyone notice something like this?
Old Nov 28, 2018 | 03:20 PM
armcclure's Avatar
it's been known since 05 that cyl4 runs hot. it's at the end of the cooling chain.
Old Jan 7, 2019 | 01:40 PM
steelmesh's Avatar
If my analysis is correct:
Out coolant pump -> Cyl 1 water jacket -> flow across Cyl 2-3-4 water jackets (some leakage through head gasket) -> up through rear of Cyl 4 -> Into Cyl head at Cyl 4 -> flow across Cyl 3-2-1 -> Exit head at Cyl 1 -> back down into block near Cyl 1
A possible cure I envision is to plumb a restricted hose from the outlet of the water pump directly to the Cyl 4 water jacket at a strategic location to give it priority cooling with the coolest coolant, that might be cool.
Old Jan 7, 2019 | 01:57 PM
I never run engines long enough to notice accelerated wear. How many miles did you personally put on those engines and are you sure they werent already worn before you got them?
Old Jan 7, 2019 | 03:56 PM
steelmesh's Avatar
I don't have any historical measurement data to look at this objectively which would be the only way to confirm there is an issue here. Block 1 and 3 got measured after disassembly, Block 2 is a new build and has low compression on Cyl 4. Block 2 would need some tear down to see whats up with 4, maybe stuck ring from diy groove sizing? ring seating issue? overheating problem?
Old Jan 7, 2019 | 04:05 PM
I feel like the only way to really tell would be to build a new engine and record all the measurements, then run a certain amount of miles of how you would normally drive the car(maybe 10k miles), then tear down and remeasure. Putting thermocouples in different areas of the cooling circuit during this testing would probably help prove your case. Either way, its an interesting thought.
gbpackrfan04
Aug 19, 2020 03:12 AM
Sl0wbaltSS
May 10, 2014 06:06 PM
06cobaltindallas
Aug 18, 2010 08:12 PM
Mclovin23
May 24, 2010 05:02 PM
06noscobaltss
Jun 10, 2007 09:46 AM
