Engine Size
Old Jun 28, 2011 | 06:27 AM
joshcsepegi's Avatar
You can get north of 300 out of a 2.2 turbo
Old Jun 28, 2011 | 06:31 AM
cmatthewb101's Avatar
Originally Posted by kikal8
thats probobly the SICKEST THING i have ever seen.. ha it bolts right up to the tranny and mounts. haha thats crazy. ima sell my ss and buy a baseline solstice and put a 2JZ-GT in it. ballerrr.
I've thought about it.
conerboner's Avatar
not on stock internals lol
Old Jun 28, 2011 | 04:46 PM
LS2SS's Avatar
haha you think a 2JZ will fit in a cobalt? i highlyyy highlyyyy doubt that. have you seen how big the 2JZ is?
Yes ive seen how big they are, just a thought, its possible just gotta have a whole lot of money he might as well just build the 2.2 he has
Old Jun 28, 2011 | 05:36 PM
newt's Avatar
Highest HP 2.2 I've seen is around 640whp.
So you can make up to 640whp on a 2.2, then again you can go as high as your pockets are deep.
Old Jun 28, 2011 | 05:42 PM
Shibito's Avatar
Originally Posted by Quick92RS
I wish someone would leave me their car and an $8k check just so I could RWD one for ***** and giggles. And show people how incredibly not difficult this kinda of stuff is with a little fabrication.
I love how you think it's so easy
It would take near $8k in parts, let alone the labor to do this. If $200k doesn't finish a LS2 RWD Cobalt, I don't think $8k is going to make a RWD switch happen.
Old Jun 28, 2011 | 08:00 PM
zfissette's Avatar
just buy a wrecked solstice, they have almost exactly the same wheel base and width, just cut the entire floor pan out of the solstice and the cobalt then switch the tops. expect to have to custom a dash from scratch and to be sitting further back than usual, there wont be any back seats, but its doable for under 30gs both cars included as long as your doing the custom fab yourself.
Old Jun 28, 2011 | 08:06 PM
kidcrash603's Avatar
Nissan VQ35 would fit with some fabbing, but may not clear the hood.
As for the guy saying buy a solstice and swap stuff.... you obviously haven't been under both or don't understand fabrication, LOL.
Old Jun 28, 2011 | 08:18 PM
TommyP's Avatar
AWD > FWD
If it's doable for under 30gs, then why not just buy a solstice GXP? Or an SS/TC? Both will cost half that much.
Motor swaps on a cobalt are useless if it's not a full on drag car. End of story.
Here's a good build to see
https://www.cobaltss.net/forums/adva...66/index2.html
Old Jun 28, 2011 | 10:01 PM
Quick92RS's Avatar
I'm not saying to build a drag car. I'm saying to make functional rwd. There's already a bolt in transmission that basically needs a crossmember to be complete. Driveshaft shop custom length driveshaft and rear axles for a solstice rear end. Custom rear subframe. Custom fabbed tubular front subframe will hold the motor mounts and really isn't all that hard to build. Might have to relocate the radiator further forward and move a few other things around inside the engine compartment. Custom ac/power steering/clutch lines. Extend some wiring. There's more to building a car than just buying and bolting some parts in. If you can't find it and need it, make it.
Old Jun 29, 2011 | 12:14 AM
  #36
G-Rich's Avatar
Originally Posted by TommypSS/TC
I think I'll PM ExSoccer1921 and see what he did to his. Thanks!
Old Jun 29, 2011 | 04:22 PM
  #37
kikal8's Avatar
haha dude ud have to be extremely knowledgable to do all of that with youself and maybe some friends.
Old Jun 29, 2011 | 04:43 PM
  #38
jonathan923's Avatar
you come straight from tokio drift lol a japanese motor in an american car lol
i hated that but then again the solstice build with the 2jz is crazy and am sure it was plenty of work.
Old Jun 29, 2011 | 05:30 PM
  #39
My buddy owns a shop where he specializes in VQ35 swaps, lol. He's got an '03 SpecV with the VQ35 in it, NA, and it feels as quick as my turbo car, LOL.
Old Jun 29, 2011 | 05:38 PM
  #40
BlueTurbo's Avatar
You forgot the part about completely rebuilding the front end of the car. If you could do a RWD swap with 8k, you would be the most successful fabricator in the country.
Old Jun 29, 2011 | 05:46 PM
  #41
Quick92RS's Avatar
Rebuild what in the front end of the car exactly? Reuse the cobalt knuckle with a solstice hub. Tubular subframes aren't that difficult to build if you understand how to use a jig. Relocate the steering rack to allow a trans. Possibly modify the front edge of the tunnel and firewall.
Old Jun 29, 2011 | 05:55 PM
  #42
BlueTurbo's Avatar
Customer radiator support, custom subframe, custom firewall, custom trans tunnel, custom floorpan, how is that not the entire front end exactly? The Solstice is shorter and has a smaller wheelbase, and parts don't just bolt right up. I'm not saying it can't be done. Anything is possible with enough time and money. Eight thousand bucks for a RWD swap is insane. Like I said, why aren't you making millions in fabrication with that kind of skill?
Old Jun 29, 2011 | 09:13 PM
  #43
Quick92RS's Avatar
New radiator support is unnecessary to move a radiator. You can modify the existing one to shift the radiator forward. I said the subframe would have to be done, but it isn't as difficult as people make it out to be. Firewall and trans tunnel MAY have to be modified for clearance, but a completely redesigned piece is unlikely. There's no reason you'd have to modify the floorpan. I'm not saying to completely steal the entire drivetrain out of a Solstice. Use the tranny and rear end along with front hubs and rear knuckles. Driveshaft Shop will make you a driveshaft and axles however you need them which negates the wheelbase and track width arguments.
Old Jun 30, 2011 | 07:11 PM
  #44
Leafydialupking's Avatar
Come on guys. The biggest engine that will fit in the cobalt engine bay is 2.4 litres. Although IRRC GM has had it as large as 2.6 Litres (and making 1500 hp).
Old Jun 30, 2011 | 08:02 PM
  #45
Quick92RS's Avatar
People stuff small blocks into fieros. You don't think you can fit a v6 into a cobalt?
Old Jun 30, 2011 | 09:49 PM
  #46
Click Me.
Old Jul 1, 2011 | 04:11 AM
  #47
Quick92RS's Avatar
Detecting sarcasm is difficult through text.
Old Jul 1, 2011 | 05:30 AM
  #48
USMCFieldMP's Avatar
Rattlesnake Race Shop
There is a large amount of retardation in this thread.
Old Jul 1, 2011 | 05:32 PM
  #49
FasterIsBetter's Avatar
Not to be a smart ass or anything, but they sell kits to do a rwd swap on a ford focus for 6 grand. Now thats minus engine and tranny... But still a hell of a deal. So not all rwd swaps are that expensive.
Old Jul 1, 2011 | 05:40 PM
  #50
nhanson's Avatar
theres a civic here that has a 3.2 in it...but doesnt clear the hood
