FAQ: TVS/Harrop-lsj1320 & You
Old 02-02-2009, 02:23 PM
  #101
Haz l33t wheelz.
ls1fbody's Avatar
would you reccomend cam gears?
Are we going to have to beg this out of you?
Old 02-02-2009, 02:27 PM
  #102
ralliartist's Avatar
how bout I'll just tell you what he told me.
On the stock blower, You need not rev past 7500 rpms. Unless you have cams. On the stock cams, it's pointless, the power drops off.
On the tvs, It will make power past 7500, adjustable cams gears would definitely help. Or just aftermarket cams.
Old 02-02-2009, 02:35 PM
  #103
Haz l33t wheelz.
ls1fbody's Avatar
Ok, i understand cam gears, i just don't think Area has gotten around to trying them out, if he even wants to.
Aftermarket cams, yes, but what grind?
Old 02-02-2009, 02:47 PM
  #104
the grind depends on your setup up and what you want. If you are going to have to get them custom grind, go ahead and customize the grind to your car.
Old 02-02-2009, 02:49 PM
  #105
Haz l33t wheelz.
ls1fbody's Avatar
that sounds logical enough. I just don;t know enough about duration and lift and all that to design a set.
Old 02-02-2009, 02:51 PM
  #106
you don't have to figure out all that on your own. Whoever is going to do the regrind should be able to help you figure that stuff out. Plus, comp cams, crower, area47 and others are just a phone call away. Talk to a professional, get all your goals and your setup figured out, then get them to figure out the specs for you, then get the cams done.
Old 02-02-2009, 02:54 PM
  #107
Haz l33t wheelz.
ls1fbody's Avatar
Exactly what i would do in the event i started looking for a set. Just wondering if it is truly worth it for the LSJ. seems to like timing more than anything.
Old 02-02-2009, 03:47 PM
  #108
I dunno. Personally, my goals aren't that crazy. I'm sticking with the stock cams. They are great for a street car, which is what my car is.
Old 02-02-2009, 10:33 PM
  #109
Haz l33t wheelz.
ls1fbody's Avatar
Ralli, buy a TVS, you know you want to...
Old 02-02-2009, 11:52 PM
  #110
Deathscythe's Avatar
he does....
Old 02-03-2009, 02:38 AM
  #111
I'm waiting to see the gb price on wed. Then I'm going to have to beg the wife. lol.
Old 02-03-2009, 04:47 AM
  #112
get the roses and kneepads ready just in case. lol
Old 02-03-2009, 05:27 AM
  #113
Haz l33t wheelz.
ls1fbody's Avatar
hell go to that store you've always been embarassed to go into, and buy some things if you have to! haha.
Old 02-03-2009, 09:09 AM
  #114
Billig ss/sc's Avatar
Same here, the GF is already flipping about it haha. Can't wait for OTTP to come back with the price tomorrow.
Question for you guys though, I know it's not necessary for the TVS, but what are the benefits of the LS4 TB vs stock? I know better response and all that, but what else? And if I got it would I have to custom-fab my Injen cai to fit up to it?
Old 02-03-2009, 09:18 AM
  #115
Haz l33t wheelz.
ls1fbody's Avatar
/flows better, because its bigger, and the HTV was designed for it.
thats as much as i know.
Old 02-03-2009, 09:26 AM
  #116
Yea I saw that, just wondering if anyone knew any more details about it. No biggie, just curious.
Old 02-03-2009, 09:30 AM
  #117
Haz l33t wheelz.
ls1fbody's Avatar
talk to fast98 or lsjwannabe, i got my ported one from lsj, they like it more than some of the other guys do.
Old 02-03-2009, 12:47 PM
  #118
It showed an increase of about 10-15 whp and wtq throughout the powerband. Not at the peak, but throughout the powerband, which is what matters. It's worth it. I got one that will be going on my car when I get it back together and I ported it myself.
Old 02-05-2009, 03:28 PM
  #119
Pyros777's Avatar
If I'm making more than 20psi, what will happen to my stock boost gauge? Will it just max out? What can I do about this?
Your stock boost gauge will max out, then zero out after a bit. If you want a gauge that maintains the stock look but can go higher (up to the LSJ's PCM limited 22.35psi), you may want to consider an SS T/C boost gauge. It is plug & play compatible with 05--07 supercharged models.
You can buy one here: http://www.crateenginedepot.com/stor...P2291C212.aspx
If you will be making more than 22.35psi, you will need to switch to a mechanical boost gauge like this one:
http://www.autometer.com/cat_gaugede...earch&gid=3442
Here is the how-to for the install: https://www.cobaltss.net/forums/how-guide-43/install-pics-mechanical-boost-gauge-go-exhondamans-write-up-15721/
Purchased an SS T/C gauge, put it in my 07, and the reading was off. The above info is no good.
Old 02-05-2009, 03:55 PM
  #120
scott allen's Avatar
how hard is it to install any how tos or pics?
Old 02-05-2009, 04:22 PM
  #121
WickedSS2005's Avatar
The ss/tc boost gauge? Or the TVS? There's a how-to on here. It varies slightly from a how-to to swapping pullies on the M62. Only diff is you need to make a modification to the MAP sensor and angle it to fit beneath the housing of the TVS and adjust your oil dipstick. Piece of cake.
Old 02-05-2009, 04:28 PM
  #122
glen229's Avatar
has anybody TVS'd a 2.4?
Old 02-05-2009, 04:31 PM
  #123
Not that has come forth to my knowledge
Old 02-05-2009, 10:09 PM
  #124
Omnigear's Avatar
not sticky yet?
Old 02-05-2009, 10:40 PM
  #125
HunterKiller89's Avatar
i dont think so. Im hoping to be the first TVS 2.2 though
I need money for an engine build.....any1 wanna donate?
Quick Reply: FAQ: TVS/Harrop-lsj1320 & You
