Gen 3 2.0 Project
Old Jul 30, 2013 | 06:51 AM
mongorat427's Avatar
Originally Posted by exsoccer1921
so this was a 2.4 that was then sleeved and bored roughly to be finish honed with the rotating assembly to be a 2.0?
2.0
Old Jul 30, 2013 | 07:42 AM
Tennpenn83's Avatar
Subbed. Looks like a good start for a build, man.
Old Jul 30, 2013 | 04:05 PM
It needs a rotating assembly and I have the cranks for LSJ or LNF
Old Aug 8, 2013 | 05:11 AM
Mxman38's Avatar
im pretty sure my 2.0 is sleeved.... its extremely thin but you can see it.... Your saying its just coating?
Old Aug 9, 2013 | 06:15 AM
If its a 2011 yes a coating
Well I got pistons and rods for the Gen 3. Decided to do it for LSJ . Diamond and K1 rods
Old Aug 9, 2013 | 08:15 AM
armcclure's Avatar
Click
Old Aug 9, 2013 | 06:46 PM
Speedytec's Avatar
Think I have read the Gen 3 blocks have thin casted-in liners? Maybe that's why it looks like a coating.
Old Aug 9, 2013 | 06:51 PM
They have a coating like many motorcycle engines.
Old Aug 9, 2013 | 07:01 PM
No liners. We just bored one out. All aluminum and installed .090 thick custom spun Ductile moly alloy sleeves. Standard bore
Old Aug 11, 2013 | 06:46 AM
Sale pending on this block
Old Aug 19, 2013 | 10:44 PM
  #36
raver0789's Avatar
How strong are these molly sleeves and should I do the same to the block you sent me?
Cheers.
Old Aug 19, 2013 | 10:56 PM
  #37
raver0789's Avatar
NM sent you a pm on facebook lol
Old Aug 20, 2013 | 08:22 PM
  #38
Cheers.
Very strong
Ill be putting this engine together soon
Last edited by mongorat427; Aug 20, 2013 at 08:22 PM. Reason: Automerged Doublepost
Old Sep 4, 2013 | 05:19 PM
  #39
Nfamous60's Avatar
very anxious on the turn out for a lnf
Old Sep 14, 2013 | 08:08 PM
  #40
cmiller8006's Avatar
I am going to be going to a ldk engine since my gen 2 got plagued with the coolant passage leaks. But the ldk gen 3 motors have cast in liners, I have a pic I will post soon.
Old Sep 14, 2013 | 08:22 PM
  #41
Old Sep 14, 2013 | 09:02 PM
  #42
Yep 2.4
Old Sep 14, 2013 | 09:06 PM
  #43
conerboner's Avatar
interesting. I might be buying a gen 3 block for my lsj
  #44
So what only the 2.4 is a cast in liner?
Old Sep 18, 2013 | 05:13 PM
  #45
taken from a gm powertrain article.
2011 ECOTEC 2.0L I-4 VVT DI TURBO (LHU)
Vehicle Applications
Buick Regal
Product Highlights
• Twin-scroll turbocharger
• Air-to-air intercooler
• Gen II sand-cast engine block
• Forged steel crankshaft
• Aluminum pistons with jet-spray cooling
• Rotocast aluminum cylinder head with sodium-filled exhaust valves
• DOHC with continuously variable valve timing
• Direct injection
• Cam-driven high-pressure fuel pump
• E85-capable
• Cam-driven vacuum pump
• 220 horsepower (164 kW)
• 260 lb.-ft. torque (353 Nm)
Overview
Available in the Buick Regal CXL, the Ecotec 2.0L turbo (LHU) is a next-generation derivative of the Ecotec 2.0L turbo LNF engine, introduced for the 2007 model year and the first North American engine with direct injection. It is tuned to meet the unique performance, efficiency and quietness targets of the Buick Regal and it is rated at 220 horsepower (164 kW) and 260 lb.-ft. of torque (353 Nm).
The Regal is a global car and the Ecotec 2.0L turbo's development applied the best practices of technical centers in Europe and North America. It was subjected to one of the toughest, most comprehensive validation processes ever at GM, which included millions of miles of real-world road testing in a broad range of climates and environments. The result is a powerful and efficient engine that delivers the smoothness and quietness commensurate with Buick.
As with all Ecotec engines, it features durability and technology features familiar in premium V-type engines, including low-friction hydraulic roller-finger valve operation and an electronic throttle. A hydraulic tensioner keeps the timing chain adjusted for life, and extended-life spark plugs deliver 100,000 miles (160,000 km) of service.
Additional Ecotec family traits include:
• Dual overhead camshafts (DOHC) with four valves per cylinder
• Twin counter-rotating balance shafts to cancel the second-order vibration typical in four-cylinder inline engines
• Full-circle transmission attachment and a structural oil pan that bolts to both the engine block and transmission bell housing.
Gen II Engine Block
The Ecotec 2.0L turbo sand-cast cylinder block is a superior refinement of previous Ecotec engine block castings. It is dimensionally similar with previous Ecotec turbo block variants, while providing improved structural support, as well as enabling greater control of noise, vibration and harshness.
The main bearing bulkheads, which support the crank bearings, as well as the cylinder bore walls have been significantly strengthened to support increased engine loads. Refinements to the oil distribution system enable improved oil flow throughout the engine and an expansion of the coolant jacket, along with the use of cast-in-place bore liners, allows more precise bore roundness and improves the block’s ability to dissipate heat.
Old Nov 2, 2013 | 05:43 PM
  #46
Gr8Bndimi's Avatar
Price on an LSJ short block like this?
Old Nov 2, 2013 | 08:03 PM
  #47
Using Gen 3 blocks with 88mm bore $700 which requires custom pistons/rings $600. Crank is stock LSJ $150 , 4340 rods $400 ,bearings $70 , Machine work $200 , Labor $300.
Old Nov 8, 2013 | 02:27 PM
  #48
Building a 2.1 right now using the 2.4 2012 block
Old Nov 8, 2013 | 03:06 PM
  #49
JapEatr's Avatar
South Central *********
i want a 2.5L :P
Old Nov 8, 2013 | 03:23 PM
  #50
The 2.5 is a completely new engine. Nothing interchanges with the 2.4
2.5L = 152.56in³ 88mm bore 98mm stroke
