hahn racecraft intake manifold
Old Nov 25, 2008 | 10:52 AM
Dragonsfire12345's Avatar
I got a question on this bad boy... I'm in the processing of saving up money to finish my turbo kit that I have under my bad. Now for the question... On the hahn racecraft website it says recommended for applications of 15psi or higher, I was wondering is that also a minimum or can I run oh say 10 or 11psi boost?
The turbo I have is an EVO III 16g turbo, if yall needed to know what kind of turbo it is... any other questions feel free to ask
Old Nov 25, 2008 | 10:56 AM
BoostedG5's Avatar
because you dont seeing much of a gain till you hit the 300+hp mark. You can put it on and it would help just not nearly as much as it would if you were 300+hp.
Old Nov 25, 2008 | 11:00 AM
Immortal Technique's Avatar
I'm pretty sure you'll need the mitsu flange for that turbo. Most are t3/t4
Old Nov 25, 2008 | 11:19 AM
its a td05 flange, I'm getting the vulcan equal length turbo manifold
Old Nov 25, 2008 | 11:23 AM
ebristol's Avatar
You will see gains with the Hahn IM. But if you are only going to push that low of a PSI you should consider saving some cash and buy a SC delete kit.
Old Nov 25, 2008 | 11:28 AM
I have a 2.4
Old Nov 25, 2008 | 08:59 PM
so I'm good running at 12psi with the hahn IM?
Old Nov 26, 2008 | 02:21 PM
Blown 4-banger's Avatar
I'm going to be running 0 psi on mine. I'm getting the manifold before the turbo, so I'll be N/A with that manifold. Hahn said I was fine to run it N/A. So if I'm good to run 0 boost, I think you'll be fine with 12 psi.
P.S. Nice avatar
Old Nov 26, 2008 | 03:15 PM
TurboTechRacing's Avatar
Correct
We also have this setup on www.TurboTechRacing.com
Old Nov 26, 2008 | 06:56 PM
P.S. Nice avatar
sounds good, maybe I'll do the same are you getting yours with the port fueler? and how does that work?
Originally Posted by TurboTechRacing
Correct
I know where I'll be ordering it from
Last edited by Dragonsfire12345; Nov 26, 2008 at 07:00 PM. Reason: Automerged Doublepost
Old Nov 26, 2008 | 08:50 PM
The port fueler is an extra set of holes for more injectors, so you can run a set of stock injectors in conjunction with a set of 60's. I'm not getting it, I'm just running one set of either 79 lbs/hr injectors, or 83 lbs/hr injectors on mine.
Old Nov 27, 2008 | 04:14 AM
ah I get ya, I guess thats for more ***** to the wall power...
Old Nov 27, 2008 | 05:26 PM
Sentry's Avatar
I want one so bad. I wish it wasn't like $800 though. I guess that's what you pay for a quality piece though.
I need to sell my 2.4 and go ahead and get this one and run it Na until I get boosted.
Old Nov 27, 2008 | 05:28 PM
High quality product here, USA made, TIG welded, best of the best
Old Nov 28, 2008 | 01:32 AM
and it makes the engine bay look fancy smancy
Old Nov 28, 2008 | 02:24 AM
Sharkey's Avatar
P.S. Nice avatar
i have a friend running one on his n/a built ecotec cavy. when he put it on he found it moved the powerband way up.
you can run 10psi on a stock plastic manifold so you dont need to buy the hahn intake. a friend of mine (i built the car pretty much) has a turbo ecotec pushing 12 psi on stock manifold with no issues
Old Nov 28, 2008 | 10:54 AM
I "blew" a hole in my plastic intake manifold on my Ecotec Cavalier running 12 PSI. This is a must upgrade for most all turbocharged applications!
Old Nov 28, 2008 | 06:13 PM
celicacobalt's Avatar
Im still running my composite intake manifold at 11+ psi for a while now with no issues.
Old Nov 29, 2008 | 01:06 AM
P.S. Nice avatar
got another question, are you gonna have to mess with tuning?
Old Dec 2, 2008 | 07:53 PM
pjk91's Avatar
yeah
Old Dec 6, 2008 | 12:17 PM
guess I'll just do the audio first then... don't wanna pay for tuning twice if I'm just gonna turbo the car sometime around income tax season.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
