How valve timing works
Old Nov 27, 2006 | 10:08 PM
Halfcent's Avatar
I'm old school
I have been wanting to make this thread for a long time now. I figure I'll at least get it started.
Here is a diagram of a generic 4 stroke engines valve timing;
The top, round picture is in relation to crankshaft rotation. The bottom is in linear time. Both show the same thing in different ways. Use either one as a reference.
Let's start with the exhaust valve opening after combustion. In our example, it opens at 55 degrees BDC (bottom dead center) on the power stroke. At this point, the pressure from combustion has moved the piston as much as it is going to, so the valve opens and allows the gases to begin to exit the cylinder. First, the pressure of combustion starts the gases moving out. Then, the piston pushes gas out on the exhaust stroke. Lastly, inertia continues to move the gas out all the way up to 15 degree past TDC (top dead center). That, so far, is pretty easy.
Now lets look at the intake valve. You can see it opens at 15 degrees before TDC, even though the exhaust valve is still open. This is normal, and is called overlap. It does a number of good things. First, some of the fresh intake air goes right out with the exhaust. This help tremendously with cooling the exhaust valves. Second, the fresh air fills in the space remaining in the combustion chamber while the exhaust gas leaves. This helps with scavenging out the burnt gases, insuring a cylinder full of fresh air.
Once the exhaust valve closes, the intake charge is now drawn in almost the same way the exhaust was pushed out. First, via suction from the intake stroke. Then, via inertia after BDC all the way until 60 degrees after.
This diagram shows only valve timing. What it doesn't show is is valve lift. Cams can be ground to open the valves more or less, and can open and close the valves faster or slower depending on the "ramp" of the cam lobe. Those three things in total; timing, lift, and ramp, are what make up the statistics of your cam shafts.
With this intro to valve timing, you can probably start to see why different cams are desired for a N/A engine versus a forced induction engine.
I would LOVE to see a thread in the future that lists in side by side comparison these statistics of the stock cams in each of the Ecotec engines with their aftermarket replacements. That way we could all see what exactly is so different.
Old Nov 27, 2006 | 10:14 PM
Rangerondubz's Avatar
Good info! Keep it comin
Old Nov 27, 2006 | 10:18 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Amazing Info! Keep up the good work!
Old Nov 27, 2006 | 10:35 PM
max_boost's Avatar
Great info man. Thanks a lot.
Old Sep 6, 2007 | 11:12 AM
CSM Huber's Avatar
Constant VVT?
This diagram shows only valve timing. What it doesn't show is is valve lift. Cams can be ground to open the valves more or less, and can open and close the valves faster or slower depending on the "ramp" of the cam lobe. Those three things in total; timing, lift, and ramp, and what make up the statistics of your cam shafts.
Can you provide a link to how GM does constant Variable Valve Timing? As I understand it, the cam face has a low end profile on one side (end) and a high end profile on the other. As the engine RPMs increase, the cam shaft is laterally shifted hydraulically with respect to the rocker arms towards the high end profile. I also understand that only the LE5 and LNF heads and cams use this method of VVT. So can one convert a 2.4L NA to direct injection by swapping to LNF heads? I wonder what kind of HP one could produce NA with tuning of the 2.4L Direct Injection.....
Old Sep 6, 2007 | 11:15 AM
The LNF's engine's Direct Injection is NOT part of the Cylinder head. The Injectors are actually inserted into the BLOCK itself.
Old Sep 14, 2007 | 09:38 AM
CSM Huber's Avatar
Cool
I've learned that the CVVT actually advances the cam rotation by hydraulically, laterally displacing a helically cut gear that meshes with a similar helically cut gear on the cam shaft (both intake and exhaust) providing a rotational advance in cam timing. The cam faces and profiles are standard cuts NOT the complex CNC cuts I envisioned. CVVT seems to be a 4 cylinder version of the Northstar system used in the Cadillac Division.
But I do not understand how Direct Injection can be done via the Block as you state as gasoline is injected into the cylinder while both valves are closed ; every thing I've read so far regarding GM Direct Injection compares it to a Diesel engine's injection system (on which I'm school trained {and Honor Graduate}).
At any rate Direct Injection along with CVVT seems to provide great opportunities for both power and economy depending of course on ECU programming and throttle position.
Old Sep 14, 2007 | 12:00 PM
The LNF also uses a chain driven fuel pump off the crank, and run a base fuel pressure of 1720psi!
I think I might go test one today.
Old Sep 14, 2007 | 12:05 PM
RaineMan's Avatar
holy crap... awesome diagram.
DrPuttsSS/SC's Avatar
It looks to me like that is an injector at the center of the pic, pointed toward the valves, in the head, not the block.
RaineMan's Avatar
where did you find that?
one of those of the LSJ would look killer screened onto a shirt.
Old Sep 14, 2007 | 12:13 PM
It is hard to imagine how long it took that guy to do that drawing, man what an artist!
Old Sep 14, 2007 | 12:43 PM
That's what I thought... but the local know it all NHJK... told me otherwise... maybe I'll go look at one today and find out for sure.
Old Sep 14, 2007 | 08:44 PM
Halfcent's Avatar
I'm old school
Wait, NJHK told you that the LNF injectors are mounted in the block? That's surprising, because it's wrong. It is most certainly mounted in the head. Here is a picture:
The VVT works by changing the cam timing, not by shifting the cam left and right to a different lobe profile. It has a hydraulic adjustable timing gear. Additionally, the high pressure fuel pump is not driven off a chain. It is cam driven. In your picture, it's in in the upper right corner attached to the intake cam.
Old Sep 16, 2007 | 06:58 AM
CSM Huber's Avatar
Thanks for providing the image of the head / combustion chamber "roof" with the valves, plug and injector. Also the clarification on CVVT not shifting the cam shaft left and right; however the hydraulic phase shifting mechanism on the end of the cam shafts does move "left" and "right" imparting rotational "advance" through a helical gear on the cam shaft end. The cam shafts themselves do not shift lateral, but the CVVT phasing mechanism does.
Excellent thread discussion! I for one enjoyed learning exactly how the Constant Variable Valve Timing of my 2.4L LE5 engine works. Thanks!
Old Sep 17, 2007 | 02:07 AM
WopOnTour's Avatar
Actually the "helical spline" type cam phaser is used more on the pushrod engines (and the 4.2L inline)
The VVT system used on most GM DOHC engines such as the LE5 Cobalts (and similar to the aformentioned Northstar) use a Vane type cam phasing mechanism that can control each cam through a range of approx 25 degrees.
The Vane Phaser is controlled the same way as a splined phaser, through a control valve, but internally its components are very different. Instead of using an internal piston with helical splines, a rotor with four vanes is connected to the end of the camshaft. The rotor is housed inside of the stator that is bolted to the cam gear.
The rotor and stator are not linked mechanically together as in the splined phaser. Instead, oil pressure is controlled on both sides of the vanes of the rotor, creating a hydraulic link to the stator. By varying the balance of oil pressure on either side of the vanes, the position of the camshaft can be controlled. A return spring is also incorporated under the reluctor of the phaser to help return it to a 0° (home) position where the exhaust cam is fully advanced and the intake cam fully retarded.
You can see the vane phaser mechnism in the LNF artwork above, and below is another pic showing some of the vane phaser features
During start-up, when little oil pressure is available, an internal spring-loaded locking pin keeps the rotor and stator locked together in the home position. When phasing is desired, oil pressure is applied to the phaser, unlocking the pin and approx 25° cam advance/retard can be achieved. Besides basic "event" timing this allows for variable overlap levels for improved emissions, economy and power.
HTH
Regards
WopOnTour
Old Sep 17, 2007 | 02:29 AM
o3nisoaso3's Avatar
this is great info. i never really understood how valve timing worked, just how i was supposed to adjust it with doing certain mods. where do you acquire this info from???
and my friend is turboing his lt and was wondering how he should adjust the timing best. hes basically going with the hahn kit but a different turbo, injectors, and hes buying the sct livewire but tuning it himself (idk why i told him just go with the hahn kit but he wont tell me). So how exactly would it work with turbocharging the engine, like do you keep timing the same or adjust it to help spool?
Old Sep 17, 2007 | 02:32 AM
2.4SlowassBalt's Avatar
subscribed, plan to read later.
Old Sep 17, 2007 | 02:40 AM
WopOnTour's Avatar
Oh and by the way, the 2.0LNF is going to FINALLY find it's way into the 2008 HHR SS later this year (Q:4 2007)
AND
The current .19 BETA version of HPT is capapble of tuning the LNF
(another cool tuning feature is the LNF comes from factory using WBO2)
Wop
Old Sep 17, 2007 | 09:27 AM
CSM Huber's Avatar
Thumbs up
HTH
Regards
WopOnTour
Thanks for the clarification on the ECOTEC 5 Vane Phaser CVVT used in the LNF and LE5 engines. Good technical explanation. Maybe this will help some of the tuners planning on using performance type, high lift cams avoid valve - piston interference.
Old Sep 17, 2007 | 03:10 PM
WopOnTour's Avatar
Well the VVT control mapping is still only somewhat adjustable in HP Tuner so that is currently somewhat of an untapped variable, but we're working on it!
Wop
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
DisJuan
Sep 7, 2015 04:24 PM
