IC PUMP pin out from LE5 ECU ??
Old Jul 31, 2013 | 10:16 PM
sound26's Avatar
Question IC PUMP pin out from LE5 ECU ??
ok guys
after complet install supercharger kit on my 2.4 2007 i will hope to use the ECU for control my ICpump .... beacause on the ECU w Hpt you can active the ic pump table but i dont know were put a pin wire for activate a relays on fuse boxe ....
same probleme for boost selenoil control ...
any guys can help me!!! beacause w the GM oem list pin LE5 i dont see were can use a optional pin out .... for ic pump et boost selenoil
very thanks
Old Jul 31, 2013 | 10:25 PM
SylverSS/SC's Avatar
Just wire it to a switched power source. It will be way easier if it comes on when the key is turned on.
I don't know how to wire it into the ecu so good luck with this
Old Jul 31, 2013 | 10:44 PM
Twoozofjuice's Avatar
just like he said above^ better to have it on all the time
Old Jul 31, 2013 | 11:03 PM
SlowCobaltSS's Avatar
Wire it into your DRL'S
Edit dont do that because when they turn off the IC pump will shut off
Get a toogle switch
Old Jul 31, 2013 | 11:49 PM
nhanson's Avatar
Mine is on the fuel pump fuse.
Old Aug 2, 2013 | 02:57 AM
sound26's Avatar
Thanks but i know all issue ... Its not my question .. I want pin into my ecu !!!
Old Aug 2, 2013 | 05:14 AM
OttawaMark's Avatar
Cool, may I ask why?
Old Aug 2, 2013 | 07:39 AM
Tjolley's Avatar
The pump is on all the time on the lsj.
But i have a friend with a le5 sced we want to do this also
Old Aug 3, 2013 | 01:47 AM
Verbatim's Avatar
Doesn't work that easy. the PCM is different.
The LE5 is a completely different animal.
The only way to get the boost bypass to work(who the **** wants that anyways) or the pump to work with the PCM is to switch to LSJ PCM. Then you might as well throw a LSJ head on there since you cant use VVT anymore without the E67 PCM, then you might as well do cams and adjustable gears. Hell, if your in there that far, just throw some sleeves, rods, pistons, balance shaft delete...
Just get an add a fuse; hit it on the fuel pump fuse, and run your wire. There is no reason to even bother with a toggle switch(makes no sense) or praying that the pin you found 12v on is capable of handling the amperage or voltage of the pump.
And on the boost bypass...ugh
Old Aug 3, 2013 | 01:11 PM
nhanson's Avatar
Boost bypass is a good thing to add. Im doing it here shortly. Tires always blow off from a dig. With the bypass engaged the car still has about 2-3 psi getting to it (found out on a buddies LSJ)
Old Jul 31, 2020 | 01:18 PM
caffeine's Avatar
You CAN wire the IC Pump to the E67 along with the other additional sensors
Ancient post but I feel it's worth correcting the nonsense posted in this thread. You absolutely CAN wire the intercooler pump relay to an output on the E67 just like on the LSJ ECM and you can wire the boost control solenoid to it as well. The output is programmable to turn on after a set number of seconds with the engine running. It's nice to use this output vs wiring it to run with ignition so that when youre doing things like flashing the ECM with a new tune you're not draining the battery having the pump constantly running.
Pin 16 on C3 (Grey Connector) is for the IC Pump Relay (it grounds this pin to turn the pump on)
Pin 14 on C3 is for the Boost Bypass Solenoid pin 2. Pin 1 on the solenoid should have IGN+
You can also setup the E67 to use two IAT sensors like with a factory LSJ ECM
Pin 56 on C3 is for the IAT2 sensor signal (from the 4-wire MAP sensor)
You can add in a BARO pressure sensor with these 3 pins
Pin 22 on C3 to sensor pin 2 Low Reference
Pin 38 on C3 to sensor pin 1 5V Reference
Pin 58 on C3 to sensor pin 3 Signal
and below are the pins to add for the inlet pressure sensor signal (post-TB, pre-rotors)
Pin 25 on C2 (Black) to sensor pin 2 Low Reference
Pin 41 on C2 to sensor pin 1 5V Reference
Pin 46 on C1 (Blue) to sensor pin 3 Signal
Old Jul 31, 2020 | 01:34 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
That's the kind of quality information sharing we need more of on here.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
