LNF Block With LSJ Internals And Head?
Old Nov 19, 2012 | 09:19 AM
mongorat427's Avatar
I have a couple Saab B207R blocks. Their exactly the same as the LSJ block except for the oil drainback hole which is in the same place as on the LNF. I checked all the holes and bolt holes and their all the same. These engines were all turboed.
Old Nov 19, 2012 | 11:11 AM
Powell Race Parts's Avatar
Good deal thanks for the info Jeff. Are the camshaft gears and cam position sensor the same as LSJ? thanks in advance
Old Nov 19, 2012 | 01:31 PM
cmiller8006's Avatar
Not if you nls
Your already in boost when you wot shift. No issues there.
Old Nov 19, 2012 | 01:39 PM
armcclure's Avatar
No on The gears. They have no key.
Cam sensor yes.
Old Nov 19, 2012 | 02:01 PM
Cam sensor yes.
thanks.
Old Nov 19, 2012 | 03:19 PM
mrbelvedere's Avatar
yes i completely agree and it only makes sense..... turbos ease into boost thus making it easier for the sleeves
i wouldent say that
Old Nov 19, 2012 | 03:29 PM
jrmotosports 88's Avatar
just a generalization...... of coarse there are always exceptions
Old Nov 19, 2012 | 06:21 PM
armcclure's Avatar
Depends who tunes it....
Anyway, if you're worried about the boost hit of an sc you can always ramp it in with the disable vs tps/mph table
Old Nov 19, 2012 | 06:42 PM
pressure is pressure however you make it. heat is heat etc.
whatever. my forlorn LNF bare block just sits here waiting for some lucky guy to buy it. Or not.
Old Nov 19, 2012 | 06:48 PM
armcclure's Avatar
What's the tag on it
You have my email...
Old Nov 20, 2012 | 06:43 AM
  #36
The cams are different and the heads in general are different . Exhaust port is smaller and they use different stud sizes. The cranks have a different sensor wheel style on all 3 engines so be carefull when trading cranks. I will post up a crank comparison soon. The cranks themselves are the same. Its the trigger wheel which varies.
Old Nov 20, 2012 | 06:46 AM
  #37
I still have that LSJ shortblock for you John. Its yours.
Old Nov 20, 2012 | 09:36 AM
  #38
armcclure's Avatar
The Saab head is almost like a hybrid of the l61&lsj.
The intake studs, the nub by the idler pulley, and ports are like l61. But it accepts lsj cams/ cam sensor and valve cover.
Old Nov 20, 2012 | 09:37 AM
  #39
armcclure's Avatar
Btw, op, this (lsj in lnf) is what I'm doing for my build. But with mr belvedere sleeves.
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
cw383
Sep 30, 2015 12:41 AM
Sep 28, 2015 12:51 PM
