ls1 coils
Old Oct 23, 2011 | 01:22 PM
zfissette's Avatar
ls1 coils
In looking for better coils for my lsj and coming up with nothing. there seems to be a shortage of ignition parts of any kind. However im looking at the ls1 replacement coils msd makes:
MSD Ignition 8245 - MSD Multiple Spark Coils and Coil Kits - Overview - SummitRacing.com
with the ls1 sparkplug wires it should be possible to run these with the coil packs mounted on top of the firewall side of the valve cover. just curious if anyone has any input on any other way to boost the effectiveness of the ignition system in an lsj.
ill have to cut slots in the center cover for the spark plug wires to go down through if i keep the cover at all. only other thing ive seen is the kenne bell boost a spart system which raises the voltage at the coils. very popular with the ford guys but i havent seen it on an ecotec motor. any input would be great.
Old Oct 23, 2011 | 06:39 PM
Sharkey's Avatar
the stock coils are actually quite good, really no need to upgrade till your pushing insane power
Old Oct 23, 2011 | 07:06 PM
08SSTCRD's Avatar
Agreed.
What is the issue you are experiencing??
Old Oct 23, 2011 | 08:51 PM
Leafydialupking's Avatar
Yeah, how much power are you making? Or more like, what cylinder pressures are you seeing?
Old Oct 23, 2011 | 11:11 PM
zfissette's Avatar
to be honest ive had no trouble to this point, but the 6 liter guys pushing 600 horse upgrade ignition systems religiously, we are making 300 on 2 liters without trouble, im trying to prevent an issue from occuring rather than resolving one that already exists.
Old Oct 23, 2011 | 11:46 PM
Omnigear's Avatar
what issue?
Old Oct 24, 2011 | 12:00 AM
09sscalicobalt's Avatar
zzp runs stock coils on all there cars and they make a gang of hp change the plugs leave the coils alone and be done with it
Old Oct 24, 2011 | 09:54 AM
zfissette's Avatar
doh. the 898 car had completely stock coils? nothing modified at all? thought they had switched to distributor and bumped up the ignition considerably.
Last edited by zfissette; Oct 24, 2011 at 10:21 AM. Reason: double checked the zzp car.
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
717ssbalt
Oct 2, 2015 04:01 PM
OrangeCoba
Oct 1, 2015 10:00 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
Fearedbynone
Sep 4, 2015 10:24 AM
