lsj head on le5 bottom end
Old Jan 27, 2012 | 02:04 PM
Dragonsfire12345's Avatar
One of the guys here in town has a lsj head sitting around and has no use for it. What would be the pro's and con's of putting the lsj head on the le5 block? Would it even be worth it? Now just to let yall know I plan on putting my valvetrain(including +1mm oversized valves) I have here at home in it, along with zzp cams that I'll be ordering with income tax. So what are yalls opinions?
Old Jan 27, 2012 | 02:10 PM
RooTBeeR's Avatar
will the vvt valve train work on an lsj head?
Old Jan 27, 2012 | 03:05 PM
newt's Avatar
I have this set-up currently, mind you in a J-Body.
Problem here would be IMO what to do with the ECM, as the VVT system will not work in the LSJ head.
Other than that, no real benefits, it will bump your compression up to the 11:1 range, so keep that in mind as well.
Old Jan 27, 2012 | 03:31 PM
so with higher compression, I could get more hp out of boost but its just that much harder to tune then.
Old Jan 28, 2012 | 11:01 AM
vvt system is in question as well....
Old Jan 28, 2012 | 12:11 PM
zfissette's Avatar
hp tuners should be able to deactivate the vvt.
Old Jan 28, 2012 | 12:25 PM
nhanson's Avatar
Why not keep LE5 head and utilize VVT?
Old Jan 28, 2012 | 12:27 PM
I was just wondering cuz a guy in town has a lsj head and doesn't need it anymore. Save on shipping lol If anything I'll probably just get one from elecblue06
Old Jan 28, 2012 | 12:34 PM
Kahless's Avatar
just have your head P&P and you should be able to get more out of it than a lsj head. if you really want the compression have it milled. unless the lsj head is super cheap.
Old Jan 31, 2012 | 12:40 PM
newt's Avatar
Not supposed to mill Ecotec heads.
Old Feb 1, 2012 | 01:23 AM
nhanson's Avatar
Port and polish exhaust ports. Only polish intake ports.
Utilize VVT
Old Feb 1, 2012 | 10:44 AM
newt's Avatar
Utilize VVT
Not supposed to polish intake ports, you actually lose CFM if you polish them.
The reason you polish the exhaust ports is so that carbon does not start to stick to the walls and build up.
Old Feb 1, 2012 | 11:37 AM
Leafydialupking's Avatar
You dont so much loose cfm from polishing, you loose turbulent flow, which makes the fuel not mix in with the air as well, and results in less power and a higher detonation risk.
Old Feb 1, 2012 | 01:49 PM
newt's Avatar
^^^touche, thats what I get for posting in the morning from work.
You are correct, I was up late last night flow benching my buddies GT40 cylinder heads, so I have CFM stuck in my head today..haha
Old Feb 1, 2012 | 07:04 PM
nhanson's Avatar
thanks for info
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Sep 28, 2015 12:51 PM
