LSJ Mini Build ;)
Old May 28, 2012 | 07:01 PM
rcorona8's Avatar
LSJ Mini Build ;)
I pulled the Head Off over the weekend. This is my first time diggin in into a motor and it was quite fun. The following items are going into my mini build.
1. ZZP Stage 2 blown cams.
2. Super Tech springs Kit
3. Port Head (Euthenesia)
4. Balance Shaft Delete Kit
5. ARP Head Bolts
6. Stock Head Gasket New
My current mods are :
1. M62 Ported - 2.7 pulley
2. Shorty Header to 2.5 cat back
3. Methanol Kit
4. intake
5. Injectors 60s
6. ZZP H/E
7. Dual Pass with option B
Im plannnng on revving all the way up to 7800 to 8k on a 3.0 pulley. my goal is to reach 320 330 whp. what do you guys think? My ultimate goal is to throw a bigger Supercharger. ill post a picture of my stock pistons.....tell me if this is normal.
Old May 28, 2012 | 07:15 PM
Sunburst_SS's Avatar
you running neutral balance shafts or a balance shaft delete kit? If it's the delete kit I believe you will need to run an electric water pump.
Old May 28, 2012 | 07:17 PM
carstedt's Avatar
shoulda jus built the lower end while u were tearin into it but good luck on ur goals either way im sure ull b more than pleased with the new power
Old May 28, 2012 | 07:32 PM
rcorona8's Avatar
Is this normal. pistons look beat......i guess the color of them scares me black/burned?
Old May 28, 2012 | 07:35 PM
rcorona8's Avatar
I dont have.the.funds to build the block right now.....so ill start with this and see.how it goes.
Old May 28, 2012 | 08:08 PM
rcorona8's Avatar
Im doing balance shaft delete kit and It doesnt need a electric water pump.
Old May 28, 2012 | 08:11 PM
100% METH's Avatar
Stock bottom end will be more than capable of handling the power he will be making.
Water meth
Old May 28, 2012 | 11:37 PM
InfraRedline's Avatar
Your pistons look fine. Thats just carbon from running gas. E85 makes them nice and clean
Keep this thread updated with pics!
Old May 29, 2012 | 01:43 AM
rcorona8's Avatar
Just came back from dropping my head at euthanisias place. great guy and he also told me it was just carbon on my pistons. Peace of mind. I will update with pics as I go. Tomorrow im going to begin the installation of bs delete kit.
Old May 29, 2012 | 03:21 AM
100% METH's Avatar
Looks pretty healthy for 60-70k onthe block
Old May 29, 2012 | 03:34 AM
BlkWdoSS's Avatar
If you are going to have the head machined, make sure the surface of the block is perfectly flat so that the headgasket seats correctly and doesnt leak, other than that looks like a fun build good luck man
Old May 29, 2012 | 12:05 PM
rcorona8's Avatar
Thanks. Euthanisia is taking care of all the details on the head.
Old May 29, 2012 | 12:09 PM
Melon's Avatar
how hard is the balance shaft delete to do with the motor in? i heard u had to drop it out of the car to get to that. i have cams, springs, and retainers waiting to go in but i am waiting to get it all done at once that way i'm not tearing the motor apart twice
Old May 29, 2012 | 01:40 PM
rcorona8's Avatar
It would be a good idea to do it all at once. That way you dont have to keep messing with the motor and tune. My plan is to dropped the motor just enough to have room to remove the balance shafts. Hopefully is not that much of a pain.....
Old May 29, 2012 | 05:34 PM
euthanasia's Avatar
The head is getting taken apart and hot tanked today.
Old May 29, 2012 | 05:35 PM
100% METH's Avatar
Rudy who's tuning your car for this beast setup?
Old May 29, 2012 | 07:37 PM
freakta's Avatar
similar to my setup, good luck
rcorona8's Avatar
Awsome. Thaks for the update!
Old May 29, 2012 | 07:38 PM
rcorona8's Avatar
Hmmmmm. I think my car wants to be street tune on the streets of camarillo
Old May 29, 2012 | 07:40 PM
rcorona8's Avatar
Wats ur set up and how do u like it.
Fyi, im on my phone and.cant see your sig....if u haf ur set up there.
Old May 29, 2012 | 07:45 PM
jonathan923's Avatar
nice build man, am sure u'll be hitting 300whp+ with this setup
Old May 29, 2012 | 07:51 PM
rcorona8's Avatar
nice build man, am sure ill be hitting 300whp+ with this setup
Thanks. I hope I do.320 whp will put a smile on my m62.
Old May 29, 2012 | 07:58 PM
100% METH's Avatar
I'm sure there's someone crazy enough to tune it
I dunno though, may require a lot of meth
Old May 29, 2012 | 08:23 PM
if you have E85 and a good reliable tune, you can deff pull it off man. with meth, meh.... it can be done but i wouldnt trust meth as much as E
Old May 29, 2012 | 08:25 PM
rcorona8's Avatar
It will actually require meth at its best
