Meth Pump Wiring??
Old May 6, 2011 | 06:06 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
On the pressure switch.. the not used pin labeled NC.. Connected it into that, pulled the tube out of the nozzle, pointed it to the ground. turned the ignition on (engine off)
LED Light comes on, and it starts spraying..
Now to get it to work in the NO connection on the pressure switch.
all the wires are ran correctly.. So it has to deal with the tubing and the connection to the pressure switch..
Old May 6, 2011 | 06:13 PM
ecot3c inside's Avatar
if you wanna know if it's working when you get it setup correctly, just tape it to a water bottle, then tape it somewhere safe under the hood. hit boost or level where your suppose to get injection, then check on your water bottle should be some meth in there.
Old May 6, 2011 | 06:15 PM
Okay, when the pump is getting power, the LED i have setup WILL turn on
I just verified this by moving a wire on the pressure switch to an ALWAYS ON state...
But when I move it back over to where it is supposed to be, during boost it won't light up, which means no power to the pump.
The LED I have is more than enough to verify.
Old May 6, 2011 | 06:21 PM
now there is methanol all over the ground LOL
Old May 6, 2011 | 07:16 PM
1:15 am bump
Old May 6, 2011 | 07:46 PM
In this image you can see where the boost is tapped at in the background.. is that correct???
Old May 6, 2011 | 10:02 PM
smithboy76908's Avatar
This is a diagram I drew up the other day for my setup. I'll be installing it this weekend but everything should work flawlessly this way.
Old May 7, 2011 | 04:19 AM
Mine is based off of devil's own diagrams.
the system works great.. but not under boost.
My guess is maybe i tapped the wrong hose ????
Old May 7, 2011 | 01:45 PM
BUMP for answers
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
