MP 1900 TVS Blower
Old Oct 13, 2009 | 10:04 PM
G85 SS's Avatar
Originally Posted by shadowfaxss
Interesting to see real world application. Seeing how Hot Rod Magazine (July 2009, page 96) was able to generate 371.9 hp at 7,900 rpm and 291.6 lb ft of torque on the stand. Granted, this was accomplished with cams, 22.9 psi, 24 degrees of timing, and no parasitic components such as the alternator.
Race gas as well. But that was rated at the crank. Not whp. There was a breakdown of power loss and it netted high 200's to the wheels. Sad really seeing how the TVS 1320 is capable of over 300 to the wheels on pump gas, meth and a tune. Trow race gas, cams and some other goodies that was done with the magnasun and you have ~320 IMO.
Old Oct 13, 2009 | 10:30 PM
euthanasia's Avatar
Yeah that article should have never happen. That's what happens when you need to fill pages with yesterdays deadline.
Old Oct 14, 2009 | 04:24 AM
Steven Flit's Avatar
I needz moar cooling mods.... Jr..... lol... if I didnt have work in the morning, this shiz would be re-tuned right now for some more powa!
Also, come to find out there is dyno shop local to Euthanasia and I. So I may have a figure up in a months time to show the power curve.
GMPP clutch n zzp stg1 axles will go on soon... should be more fun w/ a working clutch :/
Old Oct 14, 2009 | 07:34 AM
ralliartist's Avatar
A dyno chart to reveal some type of numbers and also to show the power curve would be very nice. I'm interested to see if the blower is like the 1320 unit where it supposedly "feels" dead compared to the M62 down low and has monster topend. I would imagine with huge amount of airflow you are seeing, it should come on very strong, linear still, but very strong.
Old Oct 14, 2009 | 11:18 AM
RednBlack's Avatar
that sc is huge!
Old Oct 14, 2009 | 11:47 AM
G85 SS's Avatar
Yea, I'm sure it does. The only reason the 1320 feels that way because it's not in it's efficiency range down low. I've run a buddy's 2.9 pullied balt with mine before I was on meth.
11.5 AFR and 15* of timing. 40 roll he got a jump on me, but once my car revved past 5K I pulled on him. Threw 3rd and kept on going right by him. The thing pulls hard up top.
I just don't see this blower making anything worth keeping because it's just way too big.
Old Oct 14, 2009 | 05:50 PM
Update...
The next tune for it will be finished shortly.
It's going to be a relatively mild meth tune(whats mild now adays ) . It will still make good power, but we have a stock bottom end to worry about here @ 22 psi.
The bypass plate on the dual pass endplate is going to get welded as we speak, so that will go on soon.
Also, a larger nozzle for the water/meth is going on to compensate for the added size of the blower. We have a 10gph and a 14gph on it's way...
To add, since Euthanasia has my 2.7 pulley and m62 supercharger. I'll be throwing my old race tune that Shaunmcdee developed on his car, and making the appropriate adjustments to his MAF so it all works smoothly.
Since we can't afford a dyno run just yet... A 40 roll against the "rape your face tune" is in order.
Until next time :P
Last edited by Steven Flit; Oct 14, 2009 at 06:43 PM. Reason: Automerged Doublepost
Old Oct 14, 2009 | 07:49 PM
damien's Avatar
I await the race.
Old Oct 15, 2009 | 03:48 AM
So the other night I went out tuning w/ Euthanasia... set the fueling to a flat 12.0 across the board, set 18-16* of spark and it was all dandy.
Dialed in the maf, yadda yadda....
Tonight I started doing a few 3rd n 2nd gear pulls, and im goin wtf... why am I seeing 11.5-11.6...
I go ahead and do a little investigation in the tune itself. I some how reset the p.e. table to 1.262 a.k.a 11.6 while messing w/ a possible new fueling table im working on.
None the less... It's pulling damn hard @ 11.6 afr hahaha
Also I noticed this blower has a slight dead spot between 3000-3400 rpm. Once your above 3400 rpm trq comes on instantaneously.
I wonder if I'll pick up more trq by richening up the midrange to roughly 11.0 and bumping spark to 20-24* range.
Old Oct 15, 2009 | 11:51 AM
XM15's Avatar
I believe the Hot Rod article showed that dead spot on the dyno graph as well. No doubt its because you're turning a bigger blower.
Old Oct 15, 2009 | 12:18 PM
  #36
Omnigear's Avatar
moar
Old Oct 16, 2009 | 05:52 PM
  #37
RA040424's Avatar
Looks like you have a keg for a blower!
Old Oct 16, 2009 | 05:53 PM
  #38
elecblue06's Avatar
inttteresting
Old Oct 16, 2009 | 05:58 PM
  #39
rico's Avatar
interesting i got 80lbs and going e85 send me one of those so i can test it too
subd for more
Old Oct 16, 2009 | 09:47 PM
  #40
Well like always
depending on the demand, possible kits can be made.
I'm developing multiple tunes for it as well. A non meth tune DD, mild meth tune, and an aggressive meth tune.
So who knows what may happen.
Old Oct 16, 2009 | 10:31 PM
  #41
rico's Avatar
very nice ill stay updated with this thread or euthanasia me and him talk alot
Old Oct 16, 2009 | 10:53 PM
  #42
Jrhdpaintball's Avatar
that thing is huge..
Old Oct 16, 2009 | 11:01 PM
  #43
RooTBeeR's Avatar
lmfao, holy crap steven!!! look at the size of that pulley!!! and i thought my stocker was big
Old Oct 16, 2009 | 11:26 PM
  #44
This is the only time you can say that btw...
Old Oct 16, 2009 | 11:31 PM
  #45
Omnigear's Avatar
how much is this blower?
Old Oct 16, 2009 | 11:34 PM
  #46
EatonTVS07's Avatar
sub'd
Old Oct 16, 2009 | 11:41 PM
  #47
ebristol's Avatar
Where did you hear that?
Old Oct 17, 2009 | 12:46 PM
  #48
It starts here https://www.cobaltss.net/forums/show...&postcount=143
and ends right around here https://www.cobaltss.net/forums/show...&postcount=157
I guess since I've never owned or driven a TVS car (though I've ridden in one, area47's to be exact) then I can't try to give an educated opinion on something. Even if YOU post up a dyno of your M62 vs your TVS and it's clear that both blowers make IDENTICAL numbers down low on the setups you are running, and the TVS makes better top end.
I guess John just likes to pick on me since I sold 1 single pass manifold and it was his design. He's still upset with me over that nonsense. But the fact is, he told me he wasn't going to sell them to the public, and to date, he still has only offered them to a handful of people.
I made my own single pass, I just used the info he gave me.
Old Oct 17, 2009 | 01:48 PM
  #49
G85 SS's Avatar
I've learned to take anything on this site with a grain of salt anymore. Most of the members on here have got to be like 17 yrs old and think they know it all. I don't even really post any of my knowledge on here anymore. No sense because I am wasting my breath with these guys.
As for the single pass deal, I think I know who you're talking about but we won't get into that. Whatever happened happened.
And yes, your statement with the TVS is just as valid regardless of if you were a passenger or driver. You still get a feel for what the car does/can do.
I'm sticking with my statement as I feel that this blower is simply too big for our application. it might give you more power than the M62 but I don't see it beating out the 1320. There have been people over 400 to the wheels with the TVS w/o spray.
Old Oct 17, 2009 | 02:10 PM
  #50
I'll 100% agree with you on that. I'm not even sure that a stroked 2.3/2.4 motor would be big enough for a TVS 1900 blower.
And 400whp has been proven. It'll happen again soon.
