Neutral balance shafts
Old Mar 13, 2007 | 03:37 AM
Gory's Avatar
The 300hp LSJ build book DOES NOT change the the balance shafts... it leaves the stock ones in. They made 300+ @ 8k rpm. Unless you plan on going over 8K rpm... you shouldn't NEED to change them. I pondered the idea for a while. A waste of $300 in a Daily Driver, if you ask me. there are a lot of much more needed things that $300 could go to.
Wrong! they only go to 7k they are crapy cast iron POS they will not stand the RPM Fair warning.
Old Mar 20, 2007 | 07:09 PM
CobaltSS313's Avatar
Hey Witt where did you buy the balance shafts from??
Old Mar 20, 2007 | 11:51 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Maybe you need to read the 300 build book again, my friend. They dyno it at 8k rpm WITH the stock shafts in the engine.
Old Mar 21, 2007 | 01:53 AM
Witt's Avatar
Cobalt Performance Parts who I think actually drop shipped them from Crate Engine Depot.
The build and the pictures of the engine on the dyno are not the same engine. The dyno pics were of GMPD designing and testing the Stage 3 pulley and PCM with higher rate valve springs and neutral balance shafts along with additional cooling mods. The engine you see retaining the stock shafts has forged pistons, ported head and high duration comp cams. A way to tell what engine you are looking at is the color of paint on the head. The cammed 7k engine is black and the 8k stage 3 engine is alluminum color.
If you need more convincing that stock balance shafts should not be taken past 7k rpm read the GM stage 3 installation manual available for download at crateenginedepot.com
Old Mar 21, 2007 | 11:26 AM
Halfcent's Avatar
I'm old school
Something else to consider here. While an increase in RPM will allow you make more horsepower, you will be losing torque. Torque peak with the stock cams is around 3000 RPM and then drops off the faster you spin. If you are going to increase your RPM's, you should also be considering a cam swap that moves the torque band to a higher RPM range, hence taking advantage of it.
Old Mar 21, 2007 | 11:42 AM
Witt's Avatar
Got 272 evo spec cams on the way just for this purpose.
Old Mar 21, 2007 | 07:06 PM
sunfirejoe's Avatar
where did u get those cams i want hooks ups, these triflows are scaring me no one has seen good numbers yet i dont think
hacadacalopolis
Oct 28, 2015 06:09 PM
DANRICKARD
Oct 1, 2015 12:08 AM
DocSvensk
Sep 27, 2015 02:24 PM
medic710
Sep 6, 2015 08:53 PM
