OFFICIAL Blown 4-banger build updates!
Ok since I've been getting A LOT of PMs asking for updates on my build, I decided to make a thread so I can update when stuff with my build happens. Well, I'm pulling the motor this weekend. The big thing that happened today was I got the pistons squared away. CP Pistons will be providing the pistons. The pistons are forged (duh), 9.5:1 compression, dual coated (teflon sides/ceramic top coating). They will have valve reliefs to acomidate (sp!?) my cam setup. CP said the pistons should handle upto 850 hp, so I ain't worried about those bad boys wussin out like the stocker
They said the pistons should be at my door in 4 weeks, I'M SO EXCITED!!!!!
Forged pistons are made by heating the aluminum solid cylinder to about 800*F, then uses a huge press with like 20 tons of force to press a form into the cylinder forming the shape of the piston. This is a far better process, makes a much stonger piston, and when it gets too hot, it melts, saving internal parts from flying chunks of piston. However it is more expensive to make.
theres also a negativ ehtough....forged pistons are also heavier than cast iron pistons, and thus are not as well suited to high revving, but most tuners find this a very easy sacrifice to make, as few people like making power by revving to 12kRPMs....besides hondas of course
X2^^^
No new updates so far. The freakin guy from COMP who was doin my cams went on vaction until the june 13th
The guy from Ferrea is basically wating for cam specs so he can send off the valvetrain.
Pistons are still being made, they have about 3 weeks to go.
This will be an awesome build. Why not the 10:1 compression pistons? Is the 9.5:1 better for a higher HP setups?
Another noobish question, what about the diamond head pistons, I was told that they were better than forged.
92mm pistons @ 8.0:1 compression.
EVO stage cam (the same profile)
Ti valve train
port the head
neutral balance shafts
get the cometic head gasket
of course, get a good performance crank and rods.....that'll leave more than a few cars in the dust
Ti valve train
port the head
since hes being given everything daddy wants and skipped the real answer, ive looked into it ill tell you. you have to go to shows already and win several of them on your own or at least place well. you have to show that you can get from show to show and let people see the car and their parts on it. you dont even get much of a discount at the lower levels. something like 10% of tires once a year when i looked into nitto. and you have to put a banner going across the top of the windshield.
Diamond is a brand of piston. You don't actually make the pistons out of diamond.
The 10:1 will make more power than the 9.5:1 at the track, but will have to be so detunes for the street that the 9.5:1 will be faster on pump gas.
We had the Banana maxed out at ~430bhp on the Aeroforce scan guage with the 10:1 pistons and 109 Octane. On pump gas it reads 280bhp, which is worse than it was on the 9.5:1 ratio.
<------ Ultra Noob
So, what compression ratio be better for compression that would run well with an y FI product (turbo, twinscrew, roots, etc)?
